Question about Neff Ovens
B1593 single oven - central control knob - when turned, temperature setting or timer setting, the figures change randomly rather than in discrete intervals. How do I fix this - what replacement part do I need?
5 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: the oven does not come on until i fiddle with the mechanical timers. i do not know how to set the timers so that the oven simply works when i want it to turn on with the temperature control. the oven
Most ranges must have one of the knobs you describe to be pushed in for manual oven.
Posted on May 20, 2009
  • 1891 Answers
SOURCE: MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Posted on Dec 09, 2009
Help - Knob positions on New World Debut single oven
Don't know how long ago you posted this but I have the same issues! The left hand dial deals with function and the fan oven setting is 2nd one. The grill setting is the furthest one round...I think. The right hand dial is temperature. 180 is at about half past. 200 is at about 40 mins past if you get my drift. All this I have kind of figured out through trial and error... Now I've just got to figure out how to change the light bulbs....
Aug 22, 2012 | Ovens
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
XL 44 Gas Range Oven temperature problem
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 06, 2008 | Ovens
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
How do I set the clock?
according to owners manuel push clock button and turn setting knob. go to this web sight to download or read the manuel
http://www.fisherpaykel.com/cooking/index.cfm?productUid=9A835408-BFF9-38F9-29262A3460B03423&section=supp
Jan 31, 2008 | Fisher and Paykel OS302SS, Stainless Steel...
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
59 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
