Question about Toshiba CF19G22 19" TV
Toshiba CF19G22 It has no power at all and don't know if simple to fix it ourselves; so probably not worth to have it repaired. Please advise. Thanks, Suzanne Babich MSJS28@aol.com
Frigidaire gallery refrigerator ice maker repair
Please give MUCH more information, model number, symptoms of problem, when did it start, and anything else you know about the problem. I assume (that's dangerous) it is not making ice. Look in the users manual for the troubleshooting guide. It will most probably give you the common causes of problems. Is there water getting to the icemaker? Is the motor activating to dump the ice? Is the ice level detector bar locked in the up position? There are many simple things you can check before you need to panic and call for help. I hope this steers you in the direction of solving your problem.
Mar 23, 2014 | Refrigerators
Toshiba 57H83 will not turn on
there is some shorting in the main board
Mar 24, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Need codes for ge universal remote for toshiba CF19G22
go to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 06, 2012 | Toshiba CF19G22 19" TV
Insignia lcd ns-ltdvd26 will not power on... Is their a fuse I can replace ?
unfortunately no. While there are fuses you have to take the tv apart to get at them and that probably would not fix what caused the fuse to blow.
From your description the problem will be something in the power supply. This can be simple/cheap or expensive/not worth fixing. You want to check to see if you have any warranty either em or extended store. Then you need to talk to Insignia or the store you bought it from and find out where/who can fix it. You also want to do a bit of window shopping and find out what a replacement tv is worth. When you know that then you can get an estimate for repairs from the repair depot. If the cost gets too high then just buy a new tv. While this type of problem is repairable it isn;t always worth doing. If the shop just replaces boards instead of doing board repairs then the repair could even cost more than the new tv does.
Regardless of brand this is a common problem on tv's., that is if the repair is cost effective to do or if its is cheaper to get a new one. As long as you know the replacement cost its easier to know when to repair or replace.
Nov 13, 2010 | Televison & Video
I plan on buying a used toshiba laptop series A135 but the current owner says the screen jumps around. is it worth fixing and can it be fixed. he said it may be a connectivity problem
It may be worth fixing. It could be something as simple as the ribbon cable connecting the laptop motherboard with the panel being loose. If it is not that, then it is probably something with the LCD controller circuitry and would be very difficult to repair
Jun 11, 2009 | Computers & Internet
Television made a popping sound then went out
Definately repairable.
Probably a blown capacitor on the Power Supply.
A repair of this nature is 99% labor - as each capacitor costs $2.
If the power supply has failed - it can be repaired for under $200 by your local TV Repairman.
There is definately no end-user fix for this.
You must seek the expertise of a qualified technician - there are potentially lethal energies stored inside the tv, and you're life isnt worth a measly $200 repair bill.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 17, 2009 | Televison & Video
Digital or analog?
As long as you are on cable you will not need a box.
Mar 28, 2008 | Toshiba CF19G22 19" TV
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
Color is Bland--Seems we're missing red color
THE PROBLEM IS THE SAME AS I HAD PREVIOUS,A PROJECTOR BULB HAS GONE ON THE RED PROJECTOR,YOU PROBABLY HAVE YOUR SOLLUTION BY NOW I HOPE SO ANYWAY.
Feb 24, 2007 | Toshiba 50H72 50" Rear Projection...
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
