Question about LG WM-2077C Front Load Washer
We just got a new lg tromm digital front load,washer the light after my first load is blinking OE, what does this mean and clothes are still wet
  • 1,543 Answers
That's actually DE (Drain Error) and I would never expect that on a first load unless use washed a rubber backed rug, pillow, or other item which might have given off a lot of stuff that could block up the filter, preventing pump out. (washer will not spin if water is not pumped out) Check the filter, located behind the access door on the front left bottom corner of the washer after using the small hose there to drain the remaining water out of the machine. If there was no obstruction in the filter, check for electrical problem,.... wire not connected to pump, etc. Wm2077 is an older model already. If it is new, call for warranty service and give servicer provider a copy of your sales slip to file with warranty claim.
Posted on Mar 18, 2011
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
Jul 28, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
An OE light comes on and the washer won't drain
I had something similar. It turned out that one of the option keys was stuck in an "in" position (did not jump back out after it was pressed) which disabled the functions of all the other keys. The lights in main dial came on but it was not possible to do anything else.
Jul 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My Tromm washer blinks an OE message, the door will open, but the wash won't finish and there is water still in the washer. Please help
OE error means the water hasn't pumped out. 1st you need to check the filter behind the flap in the bottom corner. This may be blocked a check your outlet hose where it goes into the somethimes they get blocked there sometimes. When the filters out get a torch and shine it into the hole where the filter came from to see if theres a blockage in there. If all is clear will prob require a new pump.
Dec 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
LG WM-2077C Front Load Washer Logo
133 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
