Question about Gateway Computers & Internet
Hi..i have a gateway laptop, around the vent area where the fan is suddenly gets very hot & the system cuts off. There are times when it doesn't get as hot & remains on. Is this possibly a sincer or fan problem?
    Scholar:
  • 155 Answers
The first things I would check is the dust accumulated around the fan and the heat sink.
It could be a fan problem or sometime the dust is clogging the air circulation.
Please power off your laptop and try to spray some dry air in the vent input (Probably on the bottom of your laptop) and output.
Let me know if you see any improvement.
regards
Posted on Mar 18, 2011
I have dell inspiron mini 1012 , when i turned it on booting it works then after 10 min it freeze, so i turned it off and tried to power on it worked but it didn't find the operating system, i tri
It sounds like your system might be running hot. Do you hear the fan running? If so it will turn on after it has cooled off, but once it gets hot it will turn off. If you immediately try to turn it back on, it won't work until the system has cooled off.
Laptops overheat because of the following problems:
1. Dust has clogged the Fans, Vents, CPU & Heat Sink Area
2. The FAN has stopped working
3. The Thermal Paste around the CPU and HeatSink has either dried up or is too thin to keep the system cool.
Try a can of compressed air and blow out the areas you can get to around the vents. You'll have to take the laptop apart to get to the Fan, CPU and Heatsink
Mar 30, 2012 | Dell Inspiron Mini 1012 Netbook...
Gateway m series..gets very hot and shuts down with system error
The fan that is on top of the CPU has a air vent and when that gets clogged with dust, that could cause the laptop to get hot. If you could get into the laptop then you could clear out any debris there in the vent. It could also be a bad fan or if you hear the fan spinning then the motherboard might be going bad because its not regulating the voltage.
Feb 06, 2012 | Gateway Computers & Internet
Runs very hot at times cannot leave hand on lay below keyboard area, fan is not on. When it does this I start cooling mamually by pushing fan around with paper clip thru air intake grid until it starts...
Hi rdn52...
Sounds like your cooling fan is faulty...
The computer should not get very hot like you describe...the fan should keep it cool...
Replace your cooling fan...
Please take time to rate me
Sep 24, 2011 | Gateway E-475M Notebook
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
Gateway solo 9300 powers up then cuts off
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 22, 2010 | Gateway Solo 9300 Notebook
I want to know why my computer always cut off suddenly ? size(VIAO VGN-CS36GJ)
Sep 19, 2010 | Computers & Internet
My gateway w350a laptop keeping shuting down after about 10-15 mins
Sep 15, 2010 | Gateway M305CRV Notebook
Gateway 4026GZ Notebook is over heating the fan seems to work but might only be working itermitttenly
Hi there, it could this simple solution!....check all the air vents in/on/around the laptop...make sure thse are all dust and debris free!...My dell hasd 2 little vents, one on eachside of the keyboard and then a large vent area underneath the laptop itself...
This could not be your problem, but a good chance of it !
If this helped you (or not) then please rate3!..Thank you!...
Apr 16, 2010 | Gateway 4026GZ Notebook
Hi, gateway w323-ul1 laptop cooling fan is not working.
Try blowing out junk in the fan by shooting air in the out vent. You can also try making up a very small hook with a paper clip and trying to see if you can pull out any junk.
If the Laptop is still under warranty call tech support. If not, you should still check the FAQ and knowledge base at the Gateway website.
Laptop fans don't run continuously. They normally run during boot and when the laptop gets too hot.
Oct 10, 2009 | Gateway Computers & Internet
Acertravelmate 2420 overheating
I think you have answered this issue yourself, I sugest that you obtain two items, a cooler pad, and a usb powered mini fan for carrying around
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
