Question about Washburn Taurus T14 4-String Electric Bass Guitar
I am quite new to playing the bass and i am having trouble using more than one finger to play a song (i slide everywhere and jump strings with the same finger). Are there any finger exercises or quick ways to get out of the habit
  • Washburn Master
  • 5,603 Answers
Try viewing some of the guitar instruction on YouTube,
Posted on Mar 19, 2011
How to adjust the pickup on a bass guitiar
It's a balancing act between volume and string pull. Generally I raise the treble pickup as close to the strings as possible without the strings hitting it while playing hard. Then play sustained notes and see if the pitch wavers from magnet pull. If so, lower the pickup a bit until the waver stops. Then ring up the bass pickup until the output matches the treble pickup. If that doesn't cause waver, your set. If it does, lower the bass pickup until it stops.
Feb 17, 2018 | Music
Tune Guitar strings 1,2 & 3 to Banjo and play with finger pickers. Bass strings to accompany. Developed complicated chords (Including Bass strings) I need to record this on paper - any tips?
Are you familiar with Tablature notation. It's instrument specific and instead od a regular staff you maje a duagram od the instruments strings looking down on the neck and then instead of notes the number of the fret goes on the relevant 'string'
https://www.guitartricks.com/helptab.php
and it's similar for banjo. Google tablature explained and a page comes up with a selection of instrument tabs.
Sep 15, 2017 | Bass Music
Learning to playbluegrassmusic on my guitar,and learning how to sing bass......
Most of the bluegrass is in your thumb, you play the bass strings with your thumb, and leave the rest of the job for the rest of your finger. Johnny Cash and Mark Knopfler are the two dudes who opened my eyes to bluegrass rythms. Also Johnny Can help you a lot on those bass tones try singing daily as deep as you can but don't stretch it out, just as much as you feel comfortable everyday and after a while you'll get the Barry White kinda bass sounds. And for the bluegrass thing just check the internet out there are tons of high quality in depth reviews of the thumb picking style, and try playing to a four bar backing drum track and follow it up with your thumb. And that's the rule of the thumb.
Common Bluegrass Flatpicking Licks Guitar Lesson Tutorial
Jun 13, 2017 | Music
My Fender bass guitar raddles.
your problem can most likely be fixed with a proper 'setup'. however, without seeing your bass it's not possible to pinpoint the problem. typical culprits can be depth of nut slots, overbowed neck, high fret or frets, string height at bridge, etc. all of these things work together and are effected by each other and are addressed in a setup. if you want to write to me directly, i may be able to sort of walk you through it.
hope this helps.
charlie white
red river music company
authorized martin guitar repair center
heber springs, ar
Jan 28, 2014 | Fender Music
Yamaha psr 1000
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Aug 04, 2013 | Music
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
Mar 18, 2011 | Washburn Taurus T14 4-String Electric Bass...
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Washburn Taurus T14 4-String Electric Bass Guitar Logo
78 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
rhodesworks
Are you a Washburn Music Expert? Answer questions, earn points and help others
