Question about U-Line 75WC Wine Cooler
MODEL ULN 158WC- FAN MOTOR STALLED. HUMS, NO BLADE ROTATION. COOLER WAS NOT COOLING.REMOVED BACK PANEL REALIZED FAN WAS NOT RUNNING. PLUGGED IN UNIT AND IT STARTED COOLING.
5 Suggested Answers
  • 286 Answers
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Posted on Oct 08, 2009
  • 3382 Answers
SOURCE: Uline wine cooler 9 years old, model ULN-15VWC-00.
the odds are your door gasket is leaking.
Good Luck,
Gilsh
Posted on Nov 29, 2009
  • 3600 Answers
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Posted on Feb 15, 2010
  • 135 Answers
SOURCE: MY COLD CONTROL IS BAD
go to googlr type your refrigerator brand name and parts .
if you would not get. see me e-mail wongjimmysoon@qq.com
i need brand name and model #
Posted on Jan 11, 2011
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Fan top back of unit is on and off continuely and making noise as in a failing bearing. I have removed the retaining screws, however the wiring has no disconnect to permit removal from the fan. Otherwise...
Unplug unit. Find name plate info on back of fan. It may be a 6 watt stamped CW. The rotation on small watt motors is based on looking at it from the "lead" end or rear of motor. You will have to cut the cord, WHEN UNIT IS UNPLUGGED. A new fan motor can be connected to the old cord with wire nuts. Install old blade on new fan motor.
Nov 02, 2009 | Danby DWC283BLS Wine Cooler
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Oct 30, 2009 | 1997 Ford Thunderbird LX
    Interior cooling fan has stopped spinning,
    No fuse. The obvious thing is to check the motor itself, which means it must be pulled. Once you gain access to the motor, with the power shut off to the unit, try spinning the blade to see if it is bound up.
    If it's spinning freely, remove it from the unit, and test the windings on the motor for continuity with a VOM meter. If you have no meter or access to one, or aren't familiar with electrical, then take the motor to an Appliance parts house. They can usually test it and most carry motors that are adaptable for beverage coolers. Make sure they know whether the machine is a 120 or 240 volt unit.
    If I'm not mistaken that motor runs 24/7 when cooler is powered up.
    Oct 29, 2009 | Carrier Beverage AirĀ® MarketeerĀ® MT12-1-B...
    Would like a wiring schematic for GSD2000F00WH model dishwasher motor hums but no action from motor
    I removed plug to motor, found the fan blade and rotated stiff blade til it became easy to turn reconnected plug to motor turned Dishwasher on added soap and happy days are here again
    Oct 06, 2009 | GE Dishwashers
    My ge microwave after running for about 3 to 4 minute it shuts down and will not start up again for 30 minutes model # TH903659B JVM 1650 JVM 1651 what is the problem thanks
    If the fan comes on when you put the unit into a cook cycle and all sounds normal otherwise, you most likely have a bad magnetron tube. (Google "GE magnetron failure" and watch how many complaints and articles pop up). The tube overheats and trips the thermal relay causing the unit to shut off until it cools back down and comes on.
    Very, very common problem on these models although GE will not admit it.
    Jul 11, 2008 | GE Microwave Ovens
    Ceiling fan
    There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
    Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
    U-Line 75WC Wine Cooler Logo
    176 people viewed this question
    Top U-Line Furniture Experts
    John Tripp
    John Tripp
    Michael Galve
    Michael Galve
    Sal De
    Are you an U-Line Furniture Expert? Answer questions, earn points and help others
