Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D kit lens problem...
I have an 18-55mm kit lens of the 400D. it's a USM f3.5/5.6... Last week, i brought my camera with me and took pictures around... Since then, when i got home, the plastic part in front of the lens cracked.. (pls see picture below) then after that happened, I had a hard time focusing... it was suppose to be smooth when you try to rotate it clockwise and counterclockwise. But then it's not. I think there's something that went inside it... maybe a very small piece of plastic. is there any way for a DIY solution for this?
    Scholar:
  • 62 Answers
It would be very difficult and not recommended to take appart a lens unless you can easily spot set screws around the area that you want to remove. One thing I would try is to lightly push on the broken off edges back and forth to set them up straight in as much a circular orientation as possible. Sometimes when a piece of any ring breaks off the remaining edges are facing inward or upward depending on direction of impact that caused it, and that way they rub against the encapsulating material as the ring turns.
Posted on Aug 28, 2008
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
I have a Cosina AF Macro 100mm lens that I used on
you should be able to use that lens with it. As long as it attaches to the SLR body ok. The thing to be aware of is with better technology in the newer camera you may have AF issues with that particular lens.
May 08, 2010 | Canon EOS 400D Digital Camera
My 400D won't turn on
Did you overtighten the tripod screw?
Aug 16, 2009 | Canon EOS 400D Digital Camera
My new 400D with kit lens produces dark pictures. I tried everyth
take it back and get it replaced sound like your shutter Assembly went out.
Jan 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
F stop
Sounds like your camera and your lens aren't communicating. Have you tried cleaning the contacts on the camera and the lens mount?
Sep 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Indoor photography
If you're on a budget, the 50mm f/1.8 II is a great deal, $100ish, f/1.8 is great for low light.
If you have a bit more cash, the 50mm f/1.4 has better build quality (the 1.8 is all plastic) and much better autofocusing (its USM so its fast and quiet, as well as more reliable) and its also slightly sharper.
If you want a zoom, from canon theres the 17-55 f/2.8, which has image stabilizer and USM focusing.
Also, the 24-70mm f/2.8L, which has USM, and since its an L lens, fantastic optical quality. However, it will run you over a thousand most likely.
From sigma, theres several zoom options, the 28-70mm F2.8 EX DG, 24-70mm F2.8 EX DG MACRO, and 24-60mm F2.8 EX DG. All under $800 or so.
Dec 03, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
