Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
1/ Would a 82year old be able to use it? 2/ Is it
1/ Would a 82year old be able to use it? 2/ Is it battery driven or mains power?
Brush bar not working have taken it out and cleaned it
hi John.
you have not said on what model its not working.
but if you go to this link and look for your model it might help you out.
Brush bar not working Google Search
Nov 23, 2017 | Vacuums
Wii wands do not work
1) replace batteries use VOM or DVOM mULTIMETER SEE THE VIDEO FOR TESTS.
2) clean the contacts batteries with solvent contacts cleaner
3) resolder the wires for contacts batteries
4) retight the spring contacts with pliers for Excelente cONTACTS.
5) TEST the main switch for open, or defective.
6) the power cords.
God bless you.
Jul 10, 2012 | Vacuums
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
Hi, the main box where all the wires connect to the sensor has the power on, and i've just noticed the small box where you enter the code to set the alarm does not work, yet the buttons are illuminated,...
Difficult as you didn't say what the equipment is but it sounds like there is a problem with communication between the main box and the keypad box. Have someone check that all the wires in the keypad are connected and there is no break in one of the wires. There are normally 6 connections, +ve and -ve, 2 serial connections and 2 tamper.If all the connections are ok try removing all power including the battery from the main box and reconnecting. Make sure you know all your codes including the installer code before you do this.Note if you do undo the small box the alarm may well go off!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 21, 2011 | Vacuums
My unit is a little over 2 years old, and I cannot leave the power button in the on position on the main unti any more. The power was controlled by the vacuum power nozzle whether I was using the carpet...
Why can't you leave the power switch "on" ?
Does it stay running, ot does it not run at all?
if it stays on, the power probably isnt controlled by the power nozzle, but may be controlled by a door switch on the flapper doors where you insert the hose... Make sure all the "flapper doors" are completely shut, there's probably one stuck a little open I'm guessing...
Oct 22, 2010 | Broan-NuTone VX475 Bagged Central System...
Light says its charging but it wont turn on
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
64 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
