Question about Microwave Ovens
Panasonic Model NN T964SF inverter microwave runs for less than 5 seconds and shuts off. Power control function does not work either. Pressing power control a number overrides cook time with power control number. ie: 1 min. cook time followed by power control 5 = 5 second cook time at 100% power.
  • Anonymous Dec 31, 2008
    I bought two Panasonic Inverter microwave ovens (both the same model number) within a month of each other about five years ago. They both stopped working within one week of each other! They both run for about 3 seconds and then shut down. I took one of them apart a few years ago because the timer circuit power transformer (on the circuit board) had a broken wire do to the front panel flexing when the keys were pressed. I fixed that problem by soldering in extensions to the tiny wires. Now this has happened and I'll bet it's the magnetron; probably cheaper to buy a new oven (in my case two new ovens) than replace a bad magnetron...
  • TrainSpotter Dec 31, 2008
    I bought two Panasonic Inverter microwave ovens within a month of each other about 5 years ago. They're identical, and were used equally. One of them stopped working completely a couple of years ago, and I traced that problem to a broken timer circuit power transformer lead. They fail because the transformer is mounted on the back of the keypad / circuit board, and when you press the keys and flex the pad the tiny lead wires break. I soldered extensions to them. Now one of the ovens started shutting down within 3 seconds last week, and the other one just failed exactly the same way! Panasonic must have planned obsolescence down to a science! This is a more expensive problem; probably the magnatron has failed, and they cost more than a new oven. (I won't buy Panasonic again...)
  • Microwave Ovens Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
  • Rose
    Rose May 13, 2014
    I am experiencing this problem. Considering that the nearest authorized servicer is over 40 miles away, would it be worth the time and cost to attempt repair?
Panasonic Microwave Oven starts for 5 seconds then shuts off
If it stops after exactly 7 seconds, it has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 25, 2012 | Microwave Ovens
My Panasonic microwave NN-C944S starts for 2-3 seconds, then stops. No message whatsoever. What could be the problem? Thanks.
this microwave has a history of this ,web search-panasonic nnt964sf, click on recall listing.I would contact company for reimbursment and notify the BBB
Oct 06, 2010 | Panasonic NN-T964SF Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
The microwave shuts itself off after 3-5 seconds on all cook settings
i have model # nns 977s it shut of and show H98 what is wrong?
Dec 26, 2009 | Panasonic NN-T964SF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
535 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
