Question about Logitech Cordless Mouse
I have a cordless Logitech mouse. Numbers on the under side are: M/N TRB22 also P/N 810-000787 also PID LZ 03667 Rating 3V=100mA. All equiment is new ( Christmas present from grand children). @While sending E-mail yesterday, all functions of the mouse stopped. The back up support is the keyboard numbers. I have replaced the batteries and read some of the comments from other users. Nothing there that helps.I formerly used WEBTV so I,m clue less on what to do next. Thank you in advance for your help. 412-279-0535 and preferred jbkasprowicz@hotmail.com
toolchick
  • 3 Answers
SOURCE: Repair Help+Logitech Cordless TrackMan Wheel Mouse
Do this first:
The piece with a circular loop on one end and a rectangular hook on the other end provides your wheel's "indexing": it's what makes the wheel feel like it's going "click-click-click" when you roll it. To position it:
1. Take out the black plastic support that the wheel sits in. Turn it "right side up", so that the lettering is on top and the circular hole is pointing to the right. (The wheel's axle will go in there). There should be a small hole facing toward you, rectangular on the bottom and semicircular on top.
2. Seat the metal hook. The rectangular part of the hook clides through the hole that is facing you. Now lay the hook down on the plastic support: you will see a small groove in the top of the support that the hook will lay in. the loop should now be hovering above a groove on the right side of the support (mine had a dab of yellow goo).
3. Slide the wheel's axle into the circular hole in the plastic support. The wheel's hollow side goes toward the support: The support, and the metal hook, should slide nicely into the hollow channel in the wheel (you might have to hold the hook down to slide it in). The metal hook should now sit between the knobby bumps on the wheel's hollow. If you turn the wheel, you should feel it click-click-click against the hook.
Now, seat the wheel.
1. For a right-handed trackman, the wheel-support goes to the left; the wheel goes to the right. Place the trackman on your desk in the usual position as if you were going to use it.
2. On the side of the trackman that is away from you (where your fingers would normally be), there are two vertical tracks that the wheel support fits into. One is about half an inch ahead of the other. Slide the support and wheel in there.
3. Now try rolling the wheel. It should roll fine, but you may notice that it has a bit of "play" to the left and right. That's where the other metal bit comes in.
4. Notice that the spring has a coiled section, and two legs. Hold the spring so that the legs are pointing down toward the desk. It should have its "left" foot forward.
5. Slide the spring over the wheel's right-side axle.
6. The legs sit in small grooves make of grey plastic; they're probably resting against those grooves right now. Use a small pair of pliers or tweezers to slide them in.
Put the cover back on and you're done!
Posted on Nov 04, 2008
SOURCE: MX600 Logitech laser cordless mouse, left button stops working
Just found a temporary solution (fixes the immediate problem, but it does return):
Turned the mouse off held down both buttons, turned it on, let go of both buttons. When you let go, it works again.
Posted on Jul 20, 2009
mjhedger
  • 25 Answers
SOURCE: My mouse just stopped working. I have a cordless
I would start by pressing the Connect button on the bottom of the mouse, then the Connect button on the bottom of the mouse receiver connected to your computer.
If that doesn't work, try replacing the batteries, then going through the Connect method mentioned above.
Posted on Aug 25, 2009
Testimonial: "Helpful. I did try the connect buttons. How do I replace the batteries?"
  • 366 Answers
SOURCE: cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
Posted on Dec 03, 2009
SOURCE: My cordless wave mouse not working red and green light goes mad.
i have the same problem
Posted on Jul 03, 2010
I need a driver to install it, web cam logitech rating 5v 100ma pid LZ702BC, p/n 861223-0000
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 05, 2013 | Logitech Webcam
Aug 25, 2009 | Logitech Cordless Mouse
I NEED A DRIVER TO INTAL IT
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
the above site is where you get your drivers.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Jun 01, 2009 | Logitech Webcam
I lost my driver Logitech
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3428&p_created=1142451071&p_sid=-onycYuj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjMsMjMmcF9wcm9kcz04NDQsNSwyMjE2JnBfY2F0cz0mcF9wdj0zLjIyMTYmcF9jdj0mcF9wYWdlPTE*&p_li=&p_topview=1
here you gonna find about 9 models at the bottom page tab ..try em all cause I can not locate the exact model ...they do work from one model to another usually...look in the first tab ...and choose a model with an appropriate P/N ..Im sure one of them will work ...also be carefully about the operating system they are build for ...
Good Luck !
Apr 06, 2009 | Logitech Quickcam Chat Webcam
Scroll wheel function issue VX Nano Cordless Laser Mouse
what is your serial number and model number (PID and M/N, found inside battery compartment). some mice had a recall, and there is a list which has been taken down, which i downlaoded onto my computer.
Apr 01, 2009 | Logitech VX Nano Cordless Laser Mouse
Install a Logitech cordless mouse on my desktop computer
You didn't say what model it was, so this is general. If it doesn't work, comment back, before rating, with the specific model and I will be more detailed.
Make sure you have good batteries in the mouse.
Plug the receiver into a usb port. try to keep it as close to the mouse as possible. There should be a small connect button on the receiver. Press it. Then there should be a small connect button on (under) the mouse. Press it. The mouse should begin working.
To get the most out of it, you can download software from Logitech Support
Again, if this doesn't work, comment back with the model number before rating. Thanks for using Fixya.
Nov 19, 2008 | Logitech Cordless Mouse
How do i install my webcam
i hope this link ll help u to download n install the drivers
http://www.nodevice.com/driver/company/Logitech/PC_Camera.html
good luck:-)
Sep 27, 2008 | Logitech Webcam
Logitech QuickCam Communicate 5-Pack Personal Web Camera
Normal 0 Go to this site
Then
Search by Image
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System. Then you will get your download driver.
Hope this helps. Bud
Aug 14, 2008 | Logitech QuickCam Communicate
Logitech Cordless Mouse Logo
173 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
