Question about Watches
I have a Michele Watch MW2 Square model 71-750. With a 24mm ss link band. The band broke away at the pin site, now what remains of the pin is stuck in the end of the quick release pin holder.What to do.. Can a regular jewler fix this
SOURCE: Armitron mens watch band link removal
I bought Armitron Automatic Watch, and its wrist band is sikmillar as tmell1.
And, thank you to idavee.
I just refered
http://www.webjeweller.com/jewellery/removelinks.shtml
Then found it as "Pin Type I."
Posted on Jul 20, 2008
SOURCE: link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
Posted on Oct 27, 2008
  • 51 Answers
SOURCE: how to adjust watch band on relic steel watch
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Cheers
Critter
Posted on Dec 26, 2008
  • 2501 Answers
SOURCE: i have an easy question. i have a kenneth cole
Your watch is made by the Geneva Watch Group, their web site is :- http://www.genevawatchgroup.com/
They say nothing about band replacements on their site but you can locate their HQ under "contact us" to ask them about replacements.
Posted on Jun 01, 2010
gemineye61
  • 831 Answers
SOURCE: Hi, My TimeX Expedition WR 100M has a broken
Try calling local jewelers/watchmakers or check out the following link:
http://repair-place.com/timex_repair.html
Posted on Aug 21, 2010
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
I need to buy 2 links to add to my watch can this be done can I buy links without replacing the whole band?
yes you can. but you need a particular tool to do it though. you can maybe do it with some household items depending on the brand of watch.
Aug 08, 2011 | Michele CSX Diamond watch
Plastic band broke at the end where pin goes ,is f...
Go to their web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html and you will arrive at a page with ordering info. on how to buy new bands.
May 14, 2010 | Watches
How does it get sized?
You can usually have your local watch shop to shorten watchbands but if they cannot do it then you could contact Michele watches.
You could then discuss any problem you have with them.
Insert "www.michele.com/" into your search engine, at the bottom of the page on the left is a "contact us" link. Click on this for info.
Feb 16, 2010 | Michele Watches 16mm Stainless Steel Watch...
How do you adjust the watch band(remove the links)
This may seem simple to do but it is literally a ***** of a task. Best to where amplifying glasses and use a ball point pen, not a pin or pencil. Push one side of the pin in while keeping a slight outward pressure on the band. When it releases be care full not to let it fly off into the void(which they can) and then move to where you need the band to be and reinstall using a single edge razor blade. Just carefully align the opposite side (assuming youve alredy put one end in)place the razor blade on center and slide the remaining pin into the hole area pull the blade out slowly and listen for it to click into place.
Jul 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
How do i use the watch band link tool i just got with no instruct
Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
Do not forget to rate, please.
Feb 11, 2009 | Rolex Datejust SS
How to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Aug 24, 2008 | Casio DB360G-9A 30 Pages Telememo Watch
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Dec 25, 2007 | Watches
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
