Question about HP Computers & Internet
Error code 0303 - HP Computers & Internet
  • 391 Answers
Hi ive come across this error message does indeed mean the disk has failed...
you will need to replace the disc drive hope this helps you goodluck
Posted on Mar 18, 2011
    Problem Solver:
  • 19 Answers
When does this come up?
I have 1998 isuzu hombre I went to the local auto zone and error code was p 0303 I checked spark plugs coil pack and they are still good any other suggestions? ?
This code means that cylinder 3 is misfiring. If the coil pack is OK then check the spark plug or wire. If they are OK check the injectors. If they are OK check the oxygen sensor.
Nov 13, 2014 | Cars & Trucks
Error code 0303 HP laptop, I bought a new hdd same problem to be sure that the hdd is good I installed it on my other laptop asus g53sx and works great, no problems. For some reason HP dosen't like it.
The 303 error would indicate a failing Hard Drive, but try the following first and then re-run the HDD test - if it still fails, it would look like you'll need to replace the drive.
Click the Start Menu, click Computer, left click Local Disc C once to highlight it, right click Local Disc C and select Properties. Click the Tools tab and then click the button to 'Check the Drive for Errors'. In the following window make sure both boxes are ticked and then click Start. Part of this process will require a restart to check the drive.
Oct 30, 2013 | Computers & Internet
Error code 0303
the error code 0303 indicates that your hard drive failed - one of the sectors is damaged. You need to get a new hard drive. Get a replacement if your laptop is still under warranty. If the warranty is void, you will have to purchase a new hardrive.
Jun 06, 2013 | Computers & Internet
Error code 0303, 0502
Hi Purabi,
What were you doing when you got the error codes??
This info is required before I even attempt to answer your query.
Cheers,
Peter
Feb 26, 2013 | Compaq Presario CQ40 Series Laptop Charger...
Error 0303 short dst failed
Hi
This means a program file is missing. Just do a search of the file (short dst) on your search mechine locate and download it.
It should correct the error automatically when you restart.
Have fun!
Aug 03, 2011 | HP Compaq 6730s Notebook
It stumbles severly on take of and at each gear shift! hooked up code reader and keeps showing a code of 0303 and now its also started showing 0404 which is misfire on cylinder 3 (0303) and on cyl 4...
Probably is just time for a tuneup, unless one was recently performed, then in that case you may have gotten those 2 plug wires crossed. Another possibility is a blown headgasket which I've seen is fairly common on escorts. You may want to check for any broken, cracked, or vacuum line that has come off.
Jun 15, 2011 | 1998 Ford Escort
My laptop doesn't boot properly. I did the memory test and it passed, then I did the HD quick test and failed log error code 0303. How can I get my laptop work properly again? Thanks Valentina
Hi Valentina, the error code 0303 indicates that the one of the sector for your hard drive failed. You need to get a new hard drive. If your computers warranty is still active you can get a replacement from dell technical support if not you can also purchase one online in this web site: www.dell.com .
Apr 14, 2011 | Computers & Internet
Laptop has hp error 0303
if the error says Hard disk 1 Quick (303)
then the hard disk must have been in jeopardy or say it is not in normal condition or almost dead.. if you are under warranty then try to contact HP..
Mar 01, 2011 | HP Computers & Internet
Diagnostic log in bios return my 0303 error code. I've got a Q presario CQ60. Ty!
Is your computer still under warranty? If so, I would definitely contact HP regarding this error, which is what HP recommends in thier knowledgebase article. Resetting the BIOS shouldn't cause any information on your machine to be lost, however it's generally best to have the BIOS updated to the newest available.
Dec 17, 2010 | Computers & Internet
1998 honda crv misfire code 0303and 0304
problem solved mechanic had wires on wrong thanks
Nov 15, 2008 | 1999 Honda CR-V
Computers & Internet Logo
685 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
