Question about Garden
I have been given a honda mower i had to put a new pull start on it & new plug but wont start what can it be
    Sergeant:
  • 259 Answers
Make sure you are getting spark by removing the sparkplug and put the wire on it and ground the plug to the engine block. Pull the cord and you should see a spark between the gap of the plug. If you are getting spark the carburetor could be dirty causing the engine to starve for fuel that has to be clean and make sure the engine has enough compression which you can check with a compression gauge should be 90 or more PSI.
Posted on Mar 18, 2011
    President:
  • 1,273 Answers
Hi, W/D here.
First, make sure that the handle that has to be up to start is up. This is the one at the upper end of the push handle. You lift this handle up to where your hands are placed and then pull the start cord. (Excuse my being very basic here; I don't know how much you know about these things. It's not my intention to insult you).
If this is not the problem, remove the spark plug and reconnect the coil wire to the plug. Orient the plug where you can see the electrode with the outer metal part of the spark plug grounded to the frame or motor. When you pull the starter, you should be able to see the plug spark. If you see a spark, that's good. If no spark, you will need to check back under the cowling. Make sure that the connections where wires connect to terminals are shiny and bright. Clean each one individually. If the coil is the type that rides very close to the flywheel, make sure that the flywheel is free of rust.
If you have spark (that's good!), you'll need to check the fuel system. Make sure that you have clean, fresh fuel in the tank. Some mowers have a fuel petcock between the tank and carburetor, so look for anything in the fuel delivery line that might be an obstruction, The fuel filter may be plugged. If you pull it to clean or replace it, use a phillips head screwdriver to plug the fuel line, or catch your fuel into a container. Look for a priming bulb. If you have one, look near it for how many times it should be depressed before starting the mower. If no instructions are found, press the bulb in between 3 and 6 times, and try to start. Depending on how long the mower has sat, there may be gum deposits in the carburetor. Remove the air cleaner, and give the ait inlet a small shot of starting fluid, and attempt to crank it. If the mower will run briefly, and you had fuel up to the carburetor, try spraying the inlet to the carburetor with carburetor cleaner, waiting a while, and dosing it again. The intention is to remove the gum deposits. Respray with the starting fluid and attempt. If tha mower attempts to start, check, clean and replace the air cleaner after giving the carburetor one more shot of starting fluid.
If there is no spark, and all connections have been checked and cleaned you will need to test the electrical components.
Hope that this helps to get you running!
Best regards, --W/D--
    Problem Solver:
  • 7 Answers
Before you do anything, check for spark. This can be done by removing the spark plug boot from the spark plug and inserting a piece of round conductive metal into the boot, such as a screwdriver, etc. Make sure it makes contact with the coil wire in the boot. Have a second person hold the screwdriver near a metal part of the engine, but make sure there is no spilled fuel in the area. Your helper should also be wearing rubber gloves or such to insulate him from a shock. If there is a strong spark, take the following steps. Drain the old fuel out of the tank. (Fuel goes bad in 30 - 60 days after being purchased unless a fuel stabilizer was added at the time of purchase. Fuel stabilizer will NOT restore bad fuel.) Make sure you drain the carburetor bowl as well. Change the fuel filter (if applicable) and install a brand new plug. The new plug you just put in will be saturated with bad fuel. Honda carburetors are known for being very reliable, seldom needing a rebuild. If you are unable to do, or uncomfortable with any of these procedures, I suggest taking your mower to a small engine repair shop.
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Wont start
Flush gas tank, fill with fresh gas and Stabil. Replace air filter. Remove bowl from carb clean bowl and holes in bowl screw.
Mar 07, 2014 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Weak spark
pull flywheel and replace sheer key on flywheel to get spark on time
Feb 23, 2014 | Garden
Toro Mower wont start
take sand paper and shine up the magnetio with is on the flywheel shine them up and put you hood back on it it will start
May 12, 2013 | Toro Garden
Honda hrb423 mower wont start have checked spark plug works any other suggestions pliz
Check the air filter and ensure that the fuel is pretty new. Today's fuel goes starts to go bad after about a month. So if the gas you left gas in it from last season or put old gas in it, it may well not start. Dump out the old stuff and put in new. If it sat with old gas and changing the gas will not let it start them you may have to clean the carb.
Jul 14, 2011 | Garden
My Honda PowerBoss Pressure Washer is very, very difficult to pull the start rope,and yet when I remove the spark plug the darn thing is very easy to pull and the engine turns over easily.But when you...
I also have a Honda powered pressure washer that i have experienced the same issues with, I have found that if you pull the wand handle on & let water come out as you are trying to start it it pulls considerably easier.
Nov 10, 2010 | Garden
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you...
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
I have a Troy-Bilt Mower - Model 834. It has a Honda GVC 160cc engine. It is supposed to start after two pulls when cold and did so since I bought it in 2006. But, just recently it takes 6-10 pulls to...
sounds like the throttle cable has slipped on the side of the engine if they dont pull the choke all the way on they wont start too well. one way to find out is take your air cleaner and outer cover off so you can see in the front of the carby the put your throttle on start/choke position the choke butterfly should be closed if not check your cable.
Jul 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
