Question about Hitachi 42HDF52 Television
I just received the converter cable for the dvi to hdmi. I'm on the DVI setting and the picture is awesom! can you tell me what ports i'm supposed to put the audio cables to
  • 4 more comments
  • FRED SANCHEZ Mar 18, 2011
    ok i did that and still no sound. There's 3 audio in inputs on the tv. Composite, s video, and Y CB/PB AND Y CR/PR. I ttied them on all 3 an still nothing
    hitachi 42hdf52 tv
    atlantic broadband explorer 8300hdc box
    hitachi 42hdf52
    atlantic broadband is my provider and my box is an explorer 8300 hdc. not sure if i had responded or not.
    MUTE, VOUME, TREBLE, BASS, BALANCE, SRS WOW AND SUBWOOFER. Those are the only options in audio tab. I have the rc cable from the box connected in the audio OUT 2 going to the audio IN S video on the TV...is that where they are supposed to be?
    can i send you a picture of the back of my tv so you can tell me where to put them. i've tried them all. Do you have an email i can forward them to
    doesn't give me the option under my first question
  • Hitachi Master
  • 5,528 Answers
The audio in port for the DVI is the same one as for a RGB input (VGA) source. It is a 3.5 mm audio jack just above the S-Video input in the main input/output terminal block (to the right of the DVI and VGA inputs). To the right is the composite video output and the stereo RCA audio out jacks.
If you are using a basic HDMI to DVI cable and connecting to your computer's audio out, you need a separate 3.5 mm M/M audio patch cable. Then make sure that the default audio out is at the line out, instead of the HDMI. (The details for doing this depend on your OS. In Windows 7, click Start > Control Panel > Hardware and Sound > Sound . Then adjust the Playback device if needed.
If your audio output is stereo RCA jacks, you will need an adapter. If you already have the RCA audio cable, get a F/F RCA to M 3.5 mm adapter.
If you have a unified cable with HDMI to DVI and the audio cable splitting off (I think I saw one of these cables in a catalog once but not recently), see the above depending on the type of audio plug you have. You might need a 3.5 mm extension cable (F/M).
The manual for the Hitachi 42HDF52 is available here: http://www.retrevo.com/support/Hitachi-42HDF52-TVs-manual/id/371bh744/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
Posted on Mar 19, 2011
  • Hitachi Master
  • 6,993 Answers
you will be needing a RCA cord to be able to get audio/sound. The RCA cord I am referring to is the red and wile (Left & Right) cable.
Check the back of your TV, you will see a red and white RCA input space like wise at the back of your device. Connect the cord from "Audio out" of your device to "Audio in" at the back of your TV.
There should be sound after this connection. Below is an image of the RCA cord.
Good luck.
Posted on Mar 18, 2011
  • 2 more comments
  • Walesarumi
    Walesarumi Mar 18, 2011
    Ok, what's the make/model of your TV and also the device you want to connect it to?
  • Walesarumi
    Go to your TV menu, under sound, you should find audio settings, you can enable the sound connection from there. Or you can connect the RCA from your Atlantic broadband box to Aux of a sound system/amplifier.......
  • Walesarumi
    Hello, there should be a AV at the back of the TV. The AV comprises of Yellow, Red and white. Yellow stand for video, while red and white stands for audio. Since you have used dvi to hdmi for video, you can just use the red and white for audio. Audio in shouldn't go to s-video. it should go to AV in........ Check the back of your TV very well and you should find AV.
  • Walesarumi
    Okay, I think that would be better. To upload the picture, go straight to your first question which is at the top of the screen. underneath the question you would see " Add a comment" click it. Then click on picture and you can upload it from there. Don't click the add comment that is under my first solution but the one underneath your original question.
I have a Sony blue ray player connected to my rca TV through a HDMI cable to a HDMI to dvi adapter I get picture but no sound. How do I get the sound to work?
sir DVI is only support for video you can get video through DVI not sound if your tv have no hdmi port then please purchase adapter which is called HDMI to av converter
thanks
Sep 21, 2017 | Sony Televison & Video
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
My tv does not have an hdmi port. I have a device I'd like to import (Apple TV) I'd like to connect. It has an hdmi input for connection to the TV. Is there something I can do to be able to connect to a...
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
Jan 14, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
hi,
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
ok
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Jun 23, 2009 | Sony HT-CT100 Theater System
Televison & Video Logo
140 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
