Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
    Problem Solver:
  • 17 Answers
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
Posted on Apr 06, 2011
My makita hr3000c won't hammer what is the most likely reason
Beware that its an old type Makita where several parts are not are deliverable any more lubrication is the first reason leaking 2 seconds and if its leaking it becomes hot inside has lost its pneumatic working so the parts are become hot and will be worn soon and the person who works with leaking tools overload themselves rather than the work object.
Makita has sometimes problems in front of the impact bolts by its rotary hammers. to observate the part cilinder 331559-9 very carefull if its not torn nowhere and this applies also to part tool holder 323912-3 it must be smooth inside in front where the impact bolt is sealed
Makita HR3000C Parts Breakdown
Oct 28, 2015 | Makita Drills
Makita impact driver wobble
Many of my customers that use this tool heavily have the same problem. It's usually the Hammer Case (PN 154590-6). The nose if the case is the bushing that holds the anvil in place and sometimes wears out of round. Rarely the anvil (PN 324432-0) wears where it passes through the hammer case so check that also.
Feb 20, 2014 | Makita 18V LXT Lithium - Ion Cordless...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a BTD141 and it has been driving in screws perfectly. Am on 2nd battery charge. It has lost the hammer/impact feature. It only occurs if you push so hard you bend the screw. No long impacts. I...
could be the anvil stuck on the hammer mechanism, try locking a bit in a vise and impacting. also could be wear on the edges allowing the 2 to slide past each other
Jan 11, 2011 | Makita 18 Volt Hammer Drill Impact Driver...
Hammer on Makita model 6905H corded impact wrench 1/2 size broke.
go to web site there is a parts list for your model and order the part
May 01, 2010 | Makita 1/2" Corded Impact Wrench
My Makita BTD140 seems to be gradually losing torque. Batteries(tried 4) check out okay. It just doesn't have the power to drive screws like it used to.
If the motor is working good then check the hammer and anvil to see if they are rounded over. A weak spring under the hammer can also add to this problem. Also check the spindle and the two steel balls that hold the hammer to the spindle. Sometimes the spindle will become chipped on the edge of the grooves and let the steel balls get out of alignment in relation to the hammer.
If the motor itself is loosing power with full batteries then you will need to check the brushes and the armature for damage. If the brushes are chipped or broken you should replace both the brushes and armature. Any questions please post back.
Oct 27, 2009 | Makita LXT202 BHP451 18 Volt Hammer Drill...
How to pull apart makita 6980 impact wrench
the battery is removed. remove all screws around the outside of the drill/driver. the side comes off. the motor is a johnson motor connected to the planetary drive and hammer/anvil assembly. the motor drive extends inside the anvil via one gear off the motor. the hammer and anvil come out as one piece. if you depress the center of theanvil with an arbor press, two ball bearings come out and the escapment comes out with the spring. now you can clean the inside of the hammer and gears of the hammer drive.
Oct 20, 2009 | Makita 12V Cordless Impact Driver -...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
692 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
