Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
4 years old, replaced original battery last year with a sears battery that hada higher cranking power. Raplaced battery, mower started and 5 minutes later it shut down while idiling. It does not crank or turn over any more..any suggestions please.
    President:
  • 1,273 Answers
Hi, W/D here.
Check the battery terminals for corrosion, and make sure that the connections are shiny, bright and tight. Follow the cables from the battery, and disconnect and clean each terminal as needed. Check the voltage in the battery as it sits. If you do not have a volt meter, any auto parts store can check it for you. They can also put a load test on it to determine if the battery is capable of taking a charge. It sounds like you had just enough battery to start the mower, but not enough to sustain it, but the problem may be elsewhere. You cannot move further until the battery is proven good, or replaced.
Provided that you have a good battery and all connections are secured and cleaned, with the key on, try to bypass the solenoid with a heavy insulated wire jumper between the large terminals. If the starter turns over, the solenoid or the start switch is bad. You can test the start switch for continuity with a meter, or a cheap automotive tester.
If all of the above checks out, the problem lies in the charging system.
Best regards, and please post back with your findings, --W/D--
Posted on Mar 18, 2011
I have a Craftsman Rider model number 917.272672 the battery needed replaced so I put a 300 cca in it It started I cut grass then one week later when I tried to use it again the battery was dead agai
sounds like there is a draw charge up the battery then remove the neg cable place a test light between the battery and cable if it lights up there is a draw unplug the wiring one thing at a time when the light goes out thats the circuit with the draw there is a diode on in the charging system that goes bad so dont forget to unplug that as well
May 09, 2012 | Craftsman Garden
The mower is about 5 years old. The batterY is two years OLD and the tractor will start with a jumper battery box. When I try to crank the engine, the starter sounds like its binding but after a few...
Not necessarily the battery can be weak with a small internal failure and can cause the issue of shorting out and not staying charged. This is very common on small batteries for these mowers. The replacement batteries you get at the hardware stores are the worst culprits for going bad after just a year or 2. The main battery that comes with the tractor are usually much stouter than the replacements. Before we tear intot he charging system I would suggest a new battery or hook up a temporary car battery if you have one to see if the guage acts up, or if you have a volt ohm meter test the charging system by reading the battery as it is running. It should be between 13 and 14 volts if it is worrking correct. You can also use the old stanby tried and tested method of pulling the positve cable off the battery after the mower has been started and see if it stays running. This will give us a base to proceed from. Let me know what you have tried and what you find.
Nov 03, 2011 | Garden
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I need to replace the battery 3.5 liter v6...any suggestions...looking towards sears
The best battery offered by Sears costs about $189.99 and has a 4 year free replacement warranty (Platinum).
One can get the Gold by Sears for $109.99 or so which has higher than oem cca.
Probably the Gold would suit your needs, but if you have the extra money, the $189.99 Platinum should last for many years to come, and uses advance technology.
See It AllVideos & Product Demonstrations Know It All Product Description', 'Product Description');" href="#desc" jquery1288280245312="69">Product Description Specifications', 'Specifications');" href="#ppspecs" jquery1288280245312="70">Specifications Customer Ratings & Reviews', 'Customer Ratings & Reviews');" href="#reviewsWrap" jquery1288280245312="71">Customer Ratings & Reviews Sears Can Help', 'Sears Can Help');" href="#srshlp" jquery1288280245312="72">Sears Can Help Special Offers', 'Special Offers');" href="#spcOffWrap" jquery1288280245312="73">Special Offers Installation & Protection', 'Installation & Protection');" href="#optsSvcs" jquery1288280245312="11">Options & Services Fulfilled by Sears
Close A Fulfilled by Sears merchant stores their inventory in our warehouse. Once an item is purchased, Sears packs, ships and provides customer service for the order. These items are also eligible for options like gift wrapping and ShipVantage. Purchasing from a Fulfilled by Sears merchant is as close to buying direct from Sears as you can get letting you shop with confidence.
Product Description The P-5 Platinum Automotive Battery from DieHard features 100 minutes of reserve capacity and 740 cold cranking amps. Its corrosion-resistant high quality tin-coated brass terminals provide reliable starting power in all weather conditions. Its rugged, military-grade construction features robust casing for increased compression and offers superior vibration resistance, making it ideal for off-road applications.
  • Longer off-season storage time - show cars & classic cars
  • Ideal for luxury vehicles with multiple electronic accessories
  • Plates made of 99.99% pure virgin lead
  • High purity grade acid held safely in place by glass mats; non-spillable design
  • Absorbed Glass Mat construction provides mounting flexibility & guarantees longer service life
  • 4-Year Free Replacement; 100-Month Prorated Limited Warranty
Oct 28, 2010 | 2004 Hyundai Santa Fe
Craftsman DYT 4000 riding mower: Last year I notice the mower has lost some power. Going up hill and blowing the grass back to the bag catchers. I installed a new carburetor, magneto, fuel filter, higher...
your valves might be sticking due to old gas when you had some or the little rod clutch rod to the carb is disconnected this is just to choke it before it dies out.
I sugest that you clean out the carb out with carb cleaner and also clean the valves.
Mar 29, 2010 | Water Heaters
Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
155 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
