Question about Whirlpool Duet GHW9150P Front Load Washer
With nothing or with clothing i can hear a knocking sound and a bad vibration when running in a spin cycle. i have taken the front off and watch the shocks they don't seem to be busted, also unit is level. this problem seem to start after someone over load unit with rugs.
  • 504 Answers
Check your bearings for fault
Posted on Mar 19, 2011
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Spinning cycle smells , vibrates , smokes
http://www.youtube.com/watch?v=Uud3xDus4TQ&feature=related
if your washer sounds like this in the spin cycle you have a bad spider gear and need to replace the washer.and with all the other stuff you discribe it sounds like it's the gear.
Aug 17, 2013 | General Electric WBVH6240HWW Front Load...
Vibration
it sounds like your bearings are gone the leak could be the seal when the bearings go the seal split and that's why you have a leak the knocking is the broken bearings the next step will be black grease coming in the machine on your clothes so you might want to in vest in a new machine be for it cost you a lot more hope i have helped you
Dec 29, 2012 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
Kenmore he2plus vibrate very badly, it is level how do i fix this
My HE2T was making a horrendous sound during the spin cycle. It was making a loud clacking sound and the machine was moving all over the place.
There are two things to check. The first is that the feet are on the floor and the machine is level. The second is a bit more complex. Remove the three screws that hold the lower panel. Underneath the drum on each of the four corners are suspension rods. One side is attached to the drum and the other side is bolted to the bottom of the washer. My bolts loosened up which allowed the suspension rods to clack back up and down as the drum spun. You'll need to tighten those bolts very tight and then give it another try.
Attached on the inside of that cover is the troubleshooting guide. There is a manual diagnostic mode and you can step it to the spin cycle so that you can test the spin balance without having to run through a full cycle. Make sure you have some clothes in there during the test.
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
