Question about HP Compaq Presario C700T
My laptop is killing it's hard drives They usually fail within 6 months The last one i had was a toshiba 320gb SATA
    Master:
  • 525 Answers
You most likely have a faulty motherboard.
Posted on Mar 18, 2011
Testimonial: "Very well informed and extremely helpful in diagnosing my problem"
  • Joshua Mar 19, 2011
    thanks for your help
    is it worth going to HP and getting a new motherboard or should i get a new laptop?
  • Ikhlaq Hussain Mar 19, 2011
    if its still under warranty HP should replace it.
    take a look on www..some hp models have common problems / issues and HP are doing repairs for free... for know issues
Toshiba hdd
As far as I know it is not possible to remove a password from a hard disk. In some cases a manufacturer may be able to help, however, for security reasons I'm not sure they would.
Mar 18, 2014 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I need this controller board for MK3265GSX
Almost any SATA board will do so long as you have a free slot.
I notice you state its for a small form drive so my question it...
Are you talking about a laptop or regular PC ?
Half a question without detail gets you half an answer
Dec 10, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My laptop do not detect my hard(mk3265GSX) laptop is Dell inspiron 1600
Ensure that the hard disk is a working one and properly fix into your DELL laptop.
Best regards.
Jul 18, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
MY TOSHIBA HARD DISK MK3265GSX 320GB CANNOT DETECT TTO MY PC
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 13, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My Labtob has a very little knock and then I heared a strange sound in the Hd the it halted. I tried to make shutdown but I failed I was obliged to make forced shutdown using the power key. next time the...
Sounds like a problem with the hard drive alright. See if you can boot to a Linux Live CD such as Ubuntu and test if all the rest of your hardware is working correctly. If you can boot successfully to an Ubuntu Live CD then it would prove that the main components of the laptop are still working correctly.
If this is the case, contact the manufacturer of the laptop and see if it is covered by warranty. If not, go to your local PC store with the laptop and ask if they can do anything with the hard drive or provide a replacement.
Apr 02, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My toshiba HDD (Model-MK3265GSX) Serial Nunmbet 40LDF2NIS KK 8 EC . A has failed. It is not readable from outside. In order to recover the data, I need another good Toshiba HDD with a serial number close...
If the drive has failed then the only option to recover data is to send it to a data recovery service but these are not cheap.
Installing another drive with a close batch/serail number will not allow you to copy from a dead drive.
I would be connecting to a regular desktop computer and trying some of the free data recovery software available such as hirens boot cd.
ANY drive within the max and type supported could be used in your laptop.
Thses are common problems with laptops and in most cases I recover data (when the drive is not too damaged) as i described above.
I then install a new and often larger drive and build the system from the recovery CD's available from the laptop manufacturer.
Then old transfer any old data I recovered back to a folder on the new drive so that customers have access to anything that was saved.
The only sure way of getting everything back from a damaged drive is to send it off but that is only of use to you if your data is mission critical.
I use the cheap USB to IDE/SATA adaptors often available from good computer shops.
Feb 15, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My laptop does not see the hdd
Check your CMos setup and see if the hard drive is recognised there.
Feb 03, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
HP Compaq Presario C700T Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
