Question about Car Audio & Video
When just driving over minor bumps or potholes it makes this rattling noise like metal to metal or like something is going to fall out in the front end of my car. It at times to me sounds like more at the right then left, but its very annoying. Please advise.
    Genius:
  • 1,066 Answers
Strut mount prolly gone bad. ths strut mount is at the top of the wheel well, in the engine compartment. the top of it has a little dome, usually.
have someone fender by the wheel well and lift up on it put your hand on the strut mount and see if you can feel the knock.
Posted on Mar 18, 2011
Rattling noise
check shocks,stabilizer linkage and bushing
Feb 22, 2014 | 2004 Dodge Stratus
Rattling noise passenger side everytime i hit a pothole or hit a bump
check sway links, ball joints, tie rods and strut bushings, they can all make noise. i would guess sway links
Grinding/screeching noise when going over speed bumps
Basic check. Open hoop, turn on the car to normal tempature.
-Ask a person to help you drive but do not drive. "Apply emergency brake and Just shift to Drive and Reverse. So watch the engine .
It twists badly or not? If just little. the engine mount is okay .
If it twist a lot.>>> Replace the engine mount. (Check for transmission mount too)
Good luck.
Mai Lor
Mar 04, 2013 | Cars & Trucks
What is making a rattle noise in the front?
Check all the bushings and make sure they are not loose. General Motors bushings are prone to cracking.
Nov 02, 2012 | 2005 Chevrolet Malibu
My 2003 Ford focus is making a rattling sound by the driver side in the engine when I go over a bump or pot hole what could this be?
There are a number of things which can do that. If someone did not properly fasten the aircleaner down it will rattle. You can get a rattle out of the shielding for your Catalytic converters and sometimes gravel will get caught in the shielding and rattle with every bounce.
There is a good possibility the rattle is your front brake pads which is why they make a compound to glue the pad to the caliper. To check this, just lightly hit the brakes enough to make the calipers work and if the noise is reduced or stops, then that is your problem. Do this when going over the bumps and potholes.
Another possibility is the joint from the exhaust header to the Catalytic pipe. There is a round metallic gasket usually called a "donut" which can work loose with engine vibration. This will sometimes chirp when you go to Reverse and back to a forward gear.
I hope one of these will solve your problem.
Mar 06, 2011 | 2003 Ford Focus
RATTLING NOISE ON THE PASSENGER SIDE FRONT TIRE
The first thing to check on a rattling noise is if going over minor bumps in the road if that is when it makes noise is a sway bar link, they make a rattling noise. If you raise that wheel up you might also want to try and wobble the wheel to be sure it is not a tie rod end or ball joint. Typically I run into the sway bar links or the sway bar bushings making the noise. However ive even seen it be a rock sitting on the strut plate.
Jul 24, 2010 | 2008 Chrysler 300
RATTLE THAT COMES FROM FRONT CONSOLE AREA WHEN EXCELLERATING
you have a broken piece inside your duck system probably when you hit a pothole or bump into something being that is made of plastic chances is something broke off
Aug 02, 2009 | Chevrolet TrailBlazer Cars & Trucks
Rattling comming from the right front of my 95 toyota 4runner
the common problem is a loose shock, check it.
May 21, 2009 | 1995 Toyota 4Runner
Noise in the front end
have your sway bars checked. My front end made an awful ratteling noise and kept getting worse. I put all kinds of parts on it but finally replacing the sway bars fixed the noise
Sep 29, 2007 | Equinox (210120)
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
