Question about Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1
Briggs & Stratton 7.5 HP Intek engine on my Sears Chipper Shredder won't start when it is warm. It will start when cold but requires continued recoil starter pulling to accomplish this. Also when it is running it tends to miss under load and loses RPM.
    Sergeant:
  • 259 Answers
I would replace the sparkplug making sure it is gapped properly and put a new air filter on the engine.
Posted on Mar 18, 2011
We have a 27hp v twin briggs & strattion which back fires and surges when engine is hot
have you tried checking the lean,rich needle on the carb sounds like it's to lean. good luck
Aug 11, 2014 | Briggs AND Stratton Intek Briggs &...
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Briggs & Stratton Van Guard 16 hp D.C. Chipper with Gravity Flow. With fuel switch on and starting engine four minutes, white smoke apprears and increases gradually, then heavier and chokes itself...
Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
Good luck.
Sep 24, 2010 | Briggs & Stratton Chipper Shredder Patriot...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Jun 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1 Logo
534 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
