Question about Panasonic PT-47WX49 47" Rear Projection Television
Where is convergence located - Panasonic PT-47WX49 47" Rear Projection Television
  • Panasonic Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
where is convergence located - 69189a5.pngttp://i.fixya.net/uploads/images/69189a5.png" alt="69189a5.png" class="h_mi" />SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needswhere is convergence located - 578ba6c.jpgchanged.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 15, 2011
Rca r52wh74yx51 chasis itc222a convergence
These sets do not have convergence ICs it has convergence board most common problem with them is if you go to menu then setup and do not see convergence on menu then you have a open fuse FL231 they are located on right side of FBT flyback transfomer thier is 3 in a roll small brown rectrangler looking caps but are FUSEs it will be the one in the middle.
Aug 14, 2009 | RCA Televison & Video
Convergence
I'm assume you are referring to a non adjustable convergence option. this will occur when you have a damaged convergence chip set that is located on either the PC board or the convergence board. The location of the affected chip will vary from model to model but, in most units, this can be fixed by replacing the convergence board or chip.
May 31, 2009 | RCA HD61W66 61" Projection HDTV
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence trouble
You most likley have bad convergence amps and two burnt resistors.Part# STK392-110.Convergence circut is located @ frot of set behind speaker grill.The only reset is in the customer menu listed Convergence reset.
Jan 12, 2009 | JVC AV-65WP74 Rear Projection Television
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
My Hitachi projection TV needs convergence amps. what are convergence amps?
The convergence amps are usually located on the extreme right side of the chassis looking in from the rear of the set. Located on a large heat sink. If you respond to this post with your correct model number I will post the correct ICs for your model, and you will need to replace the six convergence resistors as well.
Jul 13, 2008 | Televison & Video
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
51PP9303H/17 convergence repair help
I would change all convergence IC not just the one that holds the red. You will need the schematic to get the resistors location.
May 01, 2008 | Televison & Video
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Converge
If the menu does not work, your problem is most likely a defective R3243 (110k 1/2watt) located near horizontal yoke connectors. Otherwise check the convergence module 9-1690, for open 1 ohm resistors. Located near large heat sink.
Jan 17, 2006 | Zenith IQ5299DT 52 in. Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
