Question about Hotpoint WF430 Front Load Washer
Dirty washing clothes come out of wash with dirty bits over them
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Posted on Aug 02, 2008
Leaving dirty marks after washing
grease or rust ?? if its rust then you most likely have an exposed metal part that has rusted (look with flashlight and mirror at edge of agitator) if its grease then you can try washing it out with a little bit of grease cutter and many non clothes washes afterward
May 27, 2016 | Washing Machines
Streaky dirty washing
try running some cleaner through the machine on a hot 60-90 degree wash cycle with no clothes in. It may take a few goes to remove the build up of soapscum from the inner drum of the appliance
Apr 09, 2014 | Hotpoint Washing Machines
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
I need to take apart my washing machine because the metal bit under the cone is corroding and if i were to put clothes in it then the clothes would get dirty. its a hoover 55m its a top loader 5.5kg i have...
Im afraid that you will have to download the service manual from the manufactures website in order to see what's happening sorry cant help eric
Dec 31, 2017 | Washing Machines
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dirt in rinse cycle causes clean clothes to come out with dirt all over them and inside of the washing tub has dirt everywhere!
Several things could be happening...The machine is NOT "spitting" all the water out and there is STILL some dirty h2o (water) in the wash. You could be putting in dirty WELL water ? If you have HARD water and your "hard water filter, cleaner not working. Your cloths could be SOOOOOOOOO dirty ( no offence !!! because there are many D I R T Y jobs that could take two(2) washings ) that they are not getting clean.
Aug 31, 2009 | Washing Machines
Dirty marks on white washing
do you do any boil washer 95 wash if you dont there will be a sludge type of paste on the door seal pull it back a bit between the drum and the seal if there is put it on a boil wash with no powder,conditioner or clothes and put in about half a mug of soad crystals staright in the drum and this should clear up .
May 29, 2009 | Whirlpool AWM8163 Front Load Washer
Dirty washing
hi clare
have you taken the agitator out and cleaned it and under it after a while they build up a scale there
cheers grant
Nov 12, 2008 | Fisher and Paykel Washing Machines
Hotpoint WF430 Front Load Washer Logo
839 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
