Question about Dryers
My dryers more dry less dry knob keeps sticking half way through and not heating up very much
    Problem Solver:
  • 14 Answers
The dryer will not advance the timer if it doesn't heat up correctly. You have a heating problem so go to the link and you can download a video to see how to test and determine which heating thermostat or component has failed and needs to be replaced.
Dryer Repair
Posted on Mar 19, 2011
My dryer works on high heat on the timed side of the knob, but won't work on the low heat and high heat (more dry, less dry or energy preferred setting)
Does this mean the timer wont move or it will not dry ? if it will not dry it is more than likely the timer , if it wont advance then you have a shorted element
Nov 03, 2015 | Dryers
Dryer knob won't advance when set on sensor drying but will on timed drying
Hello. The dryer has a pair of sensor bars mounted on the front of the filter holder. They look like long metal rails(about 6 inches or so) and are about 1/2 inch apart. When the wet clothes touch these rails, they electrically short across them, which then tells the control board to keep drying--the clothes are wet. As the water is removed from the clothes, this "keep going" signal gets less and less, causing the dryer to count down and eventually stop. There might be a problem with the wires going to these sensor bars or with the control board. If the dryer keeps going and won't shut off during "sensor dry" the wires could be shorted or the control board might have a loose connector or is defective. Since the unit is so new, the chances of lint build-up being the culprit is remote.
Aug 15, 2015 | Maytag Bravos X MEDX600XW White Electric...
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Taking a long to time to dry doesn.t get very hot
Igreat answer above now here is a great video shows how it works and what to check
Jan 04, 2011 | Dryers
Kenmore dryer #86863800 suddenly stopped heating. Having trouble figuring which thermostat or element should be replaced. This dryer has no high/low setting. Only more dry or less dry. One big knob to set...
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer shuts off in timed and auto mode half the time. it stops and the knob goes to the off position as if the clothes were dry
here is a website that addresses your problem:
http://www.askmehelpdesk.com/appliances/whirlpool-dryer-keeps-shutting-off-20202.html
Hoped it helped Tim
Oct 24, 2010 | Whirlpool GEQ9858J Dryer
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
