Washing machine didnt complete the cycle and now wont drain the water away!
    Brigadier General:
  • 6,277 Answers
(try this!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to pursuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
Door wont open after cycle has finished, have put on a different cycle didnt work either, pluged out maching for 30 min didnt work either, can you help
Hi.
The door does not open because there is water detected inside the machine. Water must be removed through the drain filter connected to drain pump.
Disconnect power.
If front loader remove the trim panel at the base of the machine. Top loader have access at the bottom or at the back.
Locate the drain filter access at one side.
Remove drain filter cap.
Collect water using containers (have them ready, a lot of water will flow out).
Put back cap and trim and reapply power.
Emptying water from drain lines is usually enough to unlock the door. If that does not work, then the door is opened reaching back side of the door latch (from inside the washer's cabinet). Access is from top, after removing panel, or from bottom. Some front loader has an emergency unlock cord inside that can be reached undoing completely the drain filter. The procedure requires disassembling and should be done by a technician.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Washing Machines
Machine doe not appear to spin completley
The pump relay is cutting out so a replacement is in need
May 15, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining away after cycle
Hello Friend,
It seems like your machine is neither Pumping nor spinning, that is why it is unable to drain the water out. In this case you should check the pump. Your washer probably has a frozen pump pulley. If so you need to replace it. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Give it a check. Do get back to us if you need any further assistance.
Thanks
Mar 05, 2010 | Hoover Nextra HNF 2137 Front Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Dishwasher will not go through complete cycle it will not take water away
most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
Jul 01, 2009 | Electrolux Dishwashers
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
