Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Hi,i have a Philips lcd 37 pf 7320a.It has the error code 14.The audio supplies problem.Does anyone have a real solution to this and dont say replace the power board.That sounds too much like Philips and they are a joke.Someone has had to figure out whats causing this problem.I have a service manual.I got it for free at www.elektrotanya.com .It says overcurrent at resistor 3a95 and then check the audio board.Whats causing the overcurrent?There has to be a individual component that is flawed.The capacitors were checked with a ESR meter.Google this tv and you will see the many people that have this problem,just no real solution then to shell out 200.00 for a board,and more than likely the fix is less than 20.00.
  • thegozs Apr 03, 2011
    Hi,the solution is replacing resistor 3318 and MP34067P"semiconductor"on power board.Total cost 4.50 in parts.Its not the audio board.You will have to use MP34067PG instead of the original.Its the green non lead version.I have to say this is a awesome tv,when the bugs are worked out.
4 Suggested Answers
  • 163 Answers
SOURCE: I have a Philips LCD
Service manual says: Error code 14 - audio power amplifier section. The tv switches to protect and blinks one long and four short flashes.
Posted on Mar 04, 2009
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
SOURCE: Philips 37PF7320A/37 won't turn on. Error code 14
http://stores.ebay.com/techfetch - search for item containing 310432847531 or 310432838621 - those are the two compatible power board models for your TV
Posted on Nov 05, 2009
TV wont power on. Upon starting green light on front of display switches to flashing red. I have already unplugged power and tried again
This should be an error code 14. Most of the Philips TVs with this code means the Audio is the problem.
The Audio board maybe shorted out causing the TV to go into "Protection Mode". I would try unplugging the Audio board from the main power supply board and main mother board to see if the TV powers up without going into Protection Mode. That should give an answer if the Audio board is bad or not.
Apr 01, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Red light flashing.set will not start up.
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My 50 in plasma has seven red lights flashing please help
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Oct 24, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights. MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD. I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!! THAT WAS ALL IT TOOK. JUST A SUGGESTION.. 1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM) 2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.) TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 19, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Error Code 63 on Phillips Plasma - what does it mean?
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips HDTV error code
Changed power board and it is working. Has been for about 1 hour.
Dec 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 05, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
