Question about Sony Handycam CCD-TRV68 Camcorder
Unable to record
My lcd screen beeps and displays the following flashing numbers: c:31:22. According to the manual, this should be easy to correct. I have tried using my battery and the wall plug in unit, I have left the tape case open to "dry because it may be moisture" and none of these work. Could it be the tape that I am using? I have always used Fuji, now I have a Maxell (but it looks cheap???) Any advice?
thanks,
Monique
    Sergeant:
    Champion:
  • 319 Answers
Battery may need replacing. Even though it takes a charge, it still may be too weak to operate the unit. Try using the power cord directly from charger. If it still fails, have unit serviced
Posted on Aug 14, 2008
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Dec 07, 2009 | Doro 830R Cordless Phone
Unsatisfactory LCD preview display
Some times user doesn't care product category thats why I asked model number.
Now, problem is bad CCD imager in DSC-T3 and this part will be replaced to bring camera in business.
Part number of CCD imager is as follows...
A-1075-408-A CCD BLOCK ASSY (Supplied with CD-535 board)
Its available in Part Store and if you have expertise in camera repair, you can do it yourself, it is easy job.
Dec 14, 2008 | Sony Cyber-Shot DSC-T3 Digital Camera
Kodak v803
Hello. We konw someone sell Kodak V803/V1003 LCD on ebay. Please visit the following link or search item number 320277003613 on ebay. Thank you
http://cgi.ebay.com/KODAK-V803-V1003-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320277003613QQihZ011QQcategoryZ64352QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 15, 2008 | Kodak V803 Digital Camera
Sony Handycam CCD-TRV68 Camcorder Logo
42 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
