Led screen only showing 3 horizontal lines not asking to select progam dial for progam selection not selecting anything dial highlighting quick 30 andsilent wash. not selecting anything else when dial is turned this is a brand new machine
    Brigadier General:
  • 6,277 Answers
You say it's a brand new machine- then you must contact the vendor/supplier immediately without attempting to find out what is wrong with it It is under guarantee, isn't it?
Sort them out ;-0)
Good luck,
John C
Posted on Mar 18, 2011
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Tip
Windows mobile internet settings
Windows Mobile
Internet
1. On the handset, press Start.
2. Scroll to and select Settings.
3. Scroll to and select Connections.
4. Scroll to and select GPRS.
5. Press Menu and select Add.
6. In the Description: field, enter Internet
7. Scroll to Connects to: and scroll horizontally to Internet.
8. Scroll to Access point: and enter mymtn.co.sz
9. Skip User name
10. Skip Password
11. Press done twice.
12. Press Menu and select Advanced.
13. Scroll to Internet connection: and scroll horizontally to Internet.
14. Press Done.
15. Press the end call button to return to the main screen.
16. Press Start.
17. Scroll to and select Internet Services.
18. Scroll to and select Internet Explorer.
19. Press Menu and select Tools>Options.
20. Scroll to and select Connections.
21. Remove the tick from Automatically detect settings.
22. Scroll to Select network: and scroll horizontally to The Internet.
23. Press Done twice
on May 23, 2014 | Cell Phones
Yellow flashing light on screen
It is Progressive Scan mode
if you don't want it then follow this
  • Press the "Menu" button. Turn the control dial and select "M."
  • 2
    Rotate the control dial and select "Prog. Scan." Press the control dial.
  • 3
    Rotate the control dial and select "Off." Press the control dial. The Progressive Scan LED light should go off.
    Performance Chip
May 23, 2012 | Sony Video Cameras
How do i connect to a bluetooth headset?
1. On the phone's main standby screen, tap the area next to the battery life indicator in the top right corner, then select the two horizontal arrows. You should now see the Connectivity menu.
2. Select "Bluetooth".
3. Make sure the section marked "Bluetooth" is set to "On".
4. Select the Paired Devices tab at the top of the screen (it looks like two "B" logos with wavy lines between them).
5. Select "Options".
6. Select "New Paired Device".
7. Switch on your Bluetooth headset or headphones, and make sure they're in pairing mode. If you're unsure how to do this, consult the manual that came with the headset/headphones.
8. Select "More Devices".
9. If your headphones appear on the list, select it. If they aren't found, try moving the headphones nearer to the phone and select the "Try Again" option.
10. The 5800 should now complete the pairing process with the headphones. (If it asks for a numerical code, you should find it in the headphones' manual.)
11. The 5800 will ask if it's okay for the headphones to connect to your phone automatically in the future. We strongly recommend saying yes because it saves a lot of bother.
12. Select "Yes" again to connect to the headphones immediately.
Nov 19, 2011 | Nokia E72 Smartphone
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
Cursor won't move down just left and right
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Nov 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
8220 , trackball wont go down
1. Select menu.
2. Select option.
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Roller ball of my balackberry 9000 not moving upwards.
Oct 25, 2009 | RIM BlackBerry Bold 9000 Smartphone
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
