Question about Sanyo DP42848 LCD TV
My 2 year old DP42848 has audio but a black screen. Tried changing out the video cables with a second set. No change - tried a signal from my DVR instead of my DVD - no change
  • rob_elston Mar 19, 2011
    Neat trick with the flashlight - apparently correctly diagnosed. Any estimate of approxamate cost to repair would be helpful.
    Appreciate the response.
  • Sanyo Master
  • 2,098 Answers
Hi Rob,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 18, 2011
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
When I turn on the TV I get sound but just a black screen on all video inputs.
change the RCA cable and be sure to connector vedio to video audio to audio good luck
Jan 12, 2011 | Sanyo DP42848 LCD TV
2 year old Sanyo DP42848 Screen turns on for a couple of seconds then turns black... Audio works fine. Help!!
You may have a defective inverter. The inverter provides the back lighting you need to see video. There is good chance the starting resistors have changed values. It would be best to replace the inverter in your case. I would have to have a schematic to find the bad resistors. Thanks for asking and show a few hands of support.
Dec 15, 2010 | Sanyo DP42849 42 in. HDTV
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
Recording from vhs to dvd with a dvr
You can get a standard audio/video cable from any Radio Shack or audio equipment store. It will most likely come as a single 3-part cable with a yellow (video), white (audio left), and red (audio right) set of connectors on each end. Most equipment that's not too old will have matching color-coded sockets marked input/output. Simply plug the video/audio cable into the vcr output and the other end into the dvr input. then connect a second cord from the vcr output to the tv input. Then with everything turned you will be seeing the final signal on the tv and you can start the dvr when you are ready to start recording.
Nov 22, 2007 | Cyberhome DVR 1600 DVD Recorder
Sanyo DP42848 LCD TV Logo
1,083 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
