Question about Microwave Ovens
It is an older model maching and it seems to be clogged and not cleaning the dishes..how do you unclog it
    Sergeant:
    Novelist:
  • 177 Answers
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Posted on Mar 18, 2011
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
Spacemaker xl1800 ge profile problem
try to reset the settings and also the unit.. if you have an easy access to clean the keypad contact it is better to clean the surface..
Sep 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GETTING FILM ON DISHES, WE HAVE CHANGED NOTHING!
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 31, 2011 | Microwave Ovens
Glasses don't rinse clean in the upper rack of the dishwasher
heatman101
Aug 15, 2011 | Microwave Ovens
Not cleaning dishes on bottom even when half empty - leaving film. using rinse aid. ran two cycles with vinegar help
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Hello I have an Inglis Soundblock II (Pretty standard) dishwasher. We have been watching it very carefull sincde our dishes stopped getting clean. All parts of the cycle seem to run well Except: There is...
    How about the water inlet electrovalves, are they sticking maybe? Is there good pressure to the water inlet electrovalves from the house plumbing?
    Apr 20, 2017 | Microwave Ovens
    Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
    Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
    Jan 07, 2011 | Microwave Ovens
    I have a Indesit DI 620 dishwasher that wont empty its water and with an error code of no 2 and 4 flashing rapidly, what can this be please ?
    You should consult your owners manual for the error code description in the back under "troubleshooting". The obvious problem is that you are not rinsing your dishes enough and the bottom drain is clogged and needs to be cleaned out. The food will clog the hole and back it up.
    Oct 09, 2010 | Microwave Ovens
    Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
    Dishwasher Spray Arms not Spinning
    How to Buy Appliance Parts Online
    Dishwasher Problems The Heating Element not Working
    heatman101
    Asker
    Sep 30, 2010 | Microwave Ovens
    Microwave Ovens Logo
    42 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
