Question about Brother Office Equipment & Supplies
Trying to install a new fuser- 120v fixing assembly on a intellifax 2800. its the roller assembly and there is a little white connector with two wires attached to it. having trouble removing this plug in. don't want to pull too hard and break something. is there a special way to dis connect this plastic connection. any help would be appreciated.
    Sergeant:
    Champion:
  • 236 Answers
Just be very careful unfortunately there is no special tool.
Posted on Mar 18, 2011
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
Ir 2016j system error e007
Your fixing film is damaged.
Replace the Fixing Film - it is not easy to do.
Call a technician to install it.
Or buy a new Fixing part : Fuser - Fixing Film Assembly 120V : FM2-3346
Fuser - Fixing Film Assembly 230V : FM2-3353
http://bopcanon.com/images/view.aspx?productId=106
I hope it helps
Dec 10, 2010 | Canon iR 2016i Black and White Copier
Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
Jul 16, 2009 | Canon Office Equipment & Supplies
Lots of Black Lines through Paper...
BEFORE YOU CHANGE DRUM UNIT, TRY CLEAN EXPOSURE GLASS RIGHT UNDER THE DRUM UNIT-USE DRY WIPE CLOTH IF THIS WON'T HELP DRUM WILL BE NEXT STEP,ALSO YOU MIGHT NEED REPACED UPPER FUSER ROLLER. GOOD LUCK
Mar 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
FAX GETS CAUGHT ON ONE SIDE AS COMING OUT
sounds like you need a new fusing unit or at least the upper fuser roller replaced.
razors
Sep 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper feed roller
The little plastic thingy you refer to is a retainer. There is indeed a way to remove it without breaking it. Carefully pry the locking hook from it's position, then remove the roller assembly complete.
Apr 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Check Paper
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
