Question about Whirlpool Microwave Ovens
Whirlpool fridge freezer problem: frost free freezer too cold with ice and fridge not cooling but light still comes on
  • 2,382 Answers
Hi, refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues Many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper Most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Considerations Though freezers and refrigerators keep their contents cold, these appliances work by isolating heat in the freezer compartment and removing it by a refrigeration process. Because many components involved in this process run at high voltages and may contain hazardous chemicals, i recommends having a professional service person perform any repairs.
Posted on Mar 18, 2011
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Microwave Ovens
Freezer working fine but fridge not gettind cold.
The first thing you need to check is whether the fan is operating, moving the cold air from the freezer to the refrigerator. If it is operating, you should be able to feel air flow in the refrigerator when the fan is operating. If you don't but the fan is operating then the cooling tubs are probably clogged with ice or frost.
Jul 20, 2011 | Smeg Microwave Ovens
FRIDGE button is set on 3, red light flashes, air system works but it is not cool for at least 1 hour, Freezer set on 4 S and works.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermistor and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it. Then make sure all the vents are clear and not being blocked by food cartons. One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem
If you find this helpful, a vote with the thumbs up would be appreciated for the free advice
Jul 13, 2011 | Microwave Ovens
Sub zero 532 fridge is not cooling porperly but freezer is fine
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 09, 2011 | Microwave Ovens
I woke up this morning to my refrigerator humming and not working. It is 5 years old. The freezer seems to be just fine. Help! It is stainless steal model PFSS5NFWASS
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Jun 13, 2011 | Microwave Ovens
Defrost heater,every 2 weeks back of freezer frosts over, fridge gets warm, manualy dethaw get 2 more weeks
heatman101
Jun 06, 2011 | Microwave Ovens
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Jan 05, 2011 | Panasonic Microwave Ovens
Microwave Ovens Logo
66 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
