Question about LG 24 in. LDS 5811 Built-in Dishwasher
Our LG is only a couple years old and was very quiet at first. It has started making a very loud groaning noise when the water is spraying. Is it a pump going out?
    Novelist:
  • 154 Answers
Hi
In Australia I have seen similar problems with some recent models of LG dishwashers. Not sure if the ones sold in the US are any different.
One common problem I have seen with LG wash pumps from dishwashers which were sold 2-4 years ago, is that the motor becomes noisy after some time. The replacement motors which I have ordered is a different one and therefore revised as the predesessor was not reliable. The replacement motor has a different mounting bracket as well.
They are fairly cheap, but to change them is very difficult. Best to get a repairer as the machine needs to be thoroughly dismantled to allow you to get to the wash pump.
Ash
Posted on Sep 14, 2011
Beko WME8772W washer not working
clean the filter first
look in the pump for any bits in it
Feb 06, 2014 | Washing Machines
My hood fan is making a loud noise, due to it has gotten moisture after a snow storm. Can i spray WD-40 onto fan to quiet the noise?
Usually the fan begins to make noise when the bearings in the fan motor become clogged with dirt or just wear out. You must get access directly to the fan housing and spray the bearings directly. This may consist of taking off a couple panels.
Dec 22, 2010 | Microwave Ovens
I have a labored groaning noise
may be compressor clamp is loose in back side check it
Jun 05, 2010 | LG LBC22520ST Stainless Steel Bottom...
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Aug 18, 2009 | LG DLE2516 Electric Dryer
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
GE Adorda dishwasher
This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
Sep 20, 2007 | Dishwashers
LG 24 in. LDS 5811 Built-in Dishwasher Logo
301 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
