My monitor keeps going to sleep mode and i cant control any buttons on it to shut it off . i cant get on line cause i have no picture
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
you should also check the leads
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 18, 2011
    Sergeant:
    Champion:
  • 236 Answers
Go into the control panel and under power settings you can make adjustments
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
How can i keep the monitor from going to sleep mode while working?
in start-up menue, go to control panel/ hardware/power options, and change your power plan, change settings for monitor and computer to 'never', this will give you control over when it shuts down or sleeps
Jun 23, 2012 | Gateway Computers & Internet
My computer keeps going into sleep mode after 2 min, how can i solve this?
Open up CONTROL PANEL and look for POWER OPTIONS. In there you can set when the harddrive and monitor shuts down to preserve power. You can also put in "never" to avoid it going into sleep mode.
Apr 23, 2011 | Computers & Internet
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
