Question about Sennheiser Wireless TV Listening System SET 840 TV
How to avoid interference? - Sennheiser Wireless TV Listening System SET 840 TV
  • 2,574 Answers
Read this article:
What affects wireless signals and how to avoid interference
and Avoid wireless radio interference
Click here to download the instructions manual ..
Posted on Mar 18, 2011
2002 Focus SVT 2.0, is this engine a non interference engine?
in my reference book it states it as an interference engine. ANY way it really doesn't matter because any person doing a cam job will always treat the engine as interference and work to avoid valve damage. That is the safest way as valves can still suffer damage in free wheeling engines.
Dec 01, 2014 | Cars & Trucks
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Cordless home phone interferes with my dlink connection...how do i solve this?
Definitely you will be facing interferences on your router due to cordless phones...
This is because both the devices work under same frequency (2.4Ghz)...
To avoid interference, both the devices has to be placed in a separate room, if it is not possible to place in different room then they need to be separated at least 15ft away from each other...
Dec 23, 2010 | D-Link DIR-615 Wireless Router
Phone interference
try looking into the settings of your router and set the channel to 6. this way the interference shall disappear, or at least be reduced. this may be happening because both of your devices use the same frequency (generally 2.4GHz). the channels were made to avoid these interferences, since wireless networks may work on frequencies close to 2.7Ghz.
Feb 06, 2010 | Belkin F5D7234-4 Router
How can avoid interference of radio stations in the Amplifier?
Well if it is a humming noise (also can kinda sound like a turbo whining)
its more than likely a bad ground on your headunit or amp check that the amps ground is put on a solid part of your cars metal and get some sand paper and get the paint off before u ground it
other things to check before u go out and buy a filter is
check that the person who installed your stereo/amp DIDNT run the POWER for the amp next to the RCA leads or speaker wire this can cause alot of interferance too and isnt recomended at all .. power wire should be run on the other side of the car to the speaker wire and rca leads
if that fails to rid the interference you can go to anygood car audio store and ask for a filter for the rca leads and also a ground and power filter to elimantae annoying interference
also check that your airal is grounded correctly to the body of ur car over time it can become loose or corrode
hope this helps
Jan 27, 2010 | Pyramid PB1281X Car Audio Amplifier
Modify a motorola T5500 to work in different frequency
Sorry. The MHz of your radio cannot be changed. And there are no "private" frequencies available for use. However, your radio is equipped with this in mind.
There are 22 frequencies built into the T5500, along with 38 Interference Eliminator Codes. The two combined offer you over 836 choices to avoid other people. And if this is not sufficient, they also have the capability Qt filtering.
http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Page 19: Interference Eliminator Codes
Page 21-22: Qt Filter
Apr 17, 2009 | Motorola Talkabout T5500 (7 Channels)...
Will the MR314 interfere with my cordless telephone?
If you have a 2.4 GHz cordless phone, then potentially the 802.11b Wireless network and the phone can interfere with one another. In order to avoid the interference, change the channel on the cordless phone or at the access point.
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
Feb 19, 2006 | NetGear MR314 802.11b
Sennheiser Wireless TV Listening System  SET 840 TV Logo
71 people viewed this question
Top Sennheiser Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Sennheiser Health and Beauty Expert? Answer questions, earn points and help others
