Question about Insignia NS-PDVD10 Portable DVD Player
How do I change the region setting on the dvd player so that I can watch dvds from both region 1 and region 2? Many thanks.
    Scholar:
    New Friend:
  • 135 Answers
If Im correct, VLC media player can play any region DVD.
Also if you go to 'my computer' then right click your DVD drive then go to 'properties' then go to 'hardware' under the dvd drive hardware, youll find a tab called 'region' you can change it from there however you can only change a certain amount of times.
good luck
kc
Posted on Mar 18, 2011
I have the 5083 dvd player, but it only seems to play region 2 dvds. I've tried going through the menus, but it asks for a country code. The codes are two letters A-Z. I'm assuming that there's...
The Country Code is just related to the Subtitles etc and nothing to do with the Region.
Most DVD Players/Recorders are set to Play the Region of DVD from the Country they were purchased from. Only some are Region Free (will play DVDs from any Country) when purchased.
Some DVD Players/Recorders can be changed to Region Free by simply entering a code on the Remotes handset or by following instructions to enter a Service Menu and change it their.
Unfortunately yours can only be changed by updating the Firwmare which is a risky and difficult process even if you know what you're doing. I wouldn't advise anyone to try it without previous experience as you could render your DVD Player/Recorder useless.
Jun 03, 2011 | LG DVD 5083 DVD Player
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
Cant play dvd baught in england. player baught in the usa
There are different region codes for dvds and the player may only be able to play dvds with a north american region code.
Sep 08, 2009 | Radio Shack Accurian LMD-5108A Portable...
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Can you change region settings on dvd players?
some dvds enable you to manually change the setting to '0' which will allow you to watch any region dvds. Have you not looked in the manual that came with it? If you have no manual what is the model number and I will see what I can do
Oct 25, 2008 | Philips Televison & Video
Panasonic SA-PT750 - changing Region restriction
The system region control is a function of the software on the DVD player. I don't believe there is a way to change the region settings on most DVD players. You can however convert your DVDs with software available online. One program is called "DVD Region & Css Free" and is available for a small price. That is perhaps one way you could approach your problem. Otherwise look for a player that will play discs from other regions.
Oct 07, 2008 | Audio Players & Recorders
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Unlocking DVD - Pioneer DV400 k
Hi Jetix,
If the DVD player is capable of playing other regions, you should be able to change the region setting through the menu section. If there isn't an option to change the region settings in the menu, then your DVD player is not able to play other DVDs from other regions.
Sincerely,
Agent Xiong
May 27, 2008 | Televison & Video
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
How can I unlock my dvd player to play American dvds please?
I have a panasonic DMR-EZ45V which only plays region 2, but some dvds i want are on only on region 1, can it be changed to play both regions?
willc
Oct 26, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
Insignia NS-PDVD10 Portable DVD Player Logo
136 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
