Question about Estate TAWS800JQ Top Load Washer
I have an Estate TAWX700JQ3 top load washer that says Extra Large Capacity. How can I find out what that capacity actually is?
    Master:
  • Estate Master
  • 610 Answers
That is meaningless. The important rule is to be sure the clothing you load in can float freely in the amount of water you give it, always use powdered detergent and the warmest water the colors involved will tolerate. Don't wash things that float, don't jam your comforters in your home machine....
Posted on Jul 26, 2016
SOURCE: estate top loading washer needs a lid switch replacement
I found one one NEW on ebay for 6.50 + shipping, total 12.49. Other parts places had them for a lot more. It wasn't too hard to install.
Posted on Dec 01, 2008
futureloginn
  • 734 Answers
SOURCE: My washer will fill up and drain, but it wont agitate or spin
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
jsrock516
  • 5911 Answers
SOURCE: My Estate by Whirlpool Corp. TAWX700JQ3 will fill up no drain,spi
The problem is usually related to a lid switch malfunction. The lid switch is located under the right-hand side of the tub rim and is activated by a small plastic piece on the lid, called a "lid strike". First, make sure the lid strike is not broken off. Second, double check the two mounting screws that hold the lid switch in place along the tub rim opening on the right-hand side. Sometimes, all that is required is to tighten the screws that hold the switch in place to realign it with the lid strike. If all parts are in place, open and shut the lid. You should hear a distinctive "clicking" sound indicating the switch is activating. If the switch still does not work, replace it. The following link explains:
http://www.fixya.com/support/r397101-replacing_lid_switch
A replacement switch can be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 9 and the lid strike is listed as item number 20. If you're exact model number is not shown, any of the listed models will do. The part numbers are still the same. You can also try any of the following other websources: repairclinic.com, pcappliancerepair.com and appliancepartspros.com. They all offer great service and competitive pricing. I hope you find this information helpful. Let me know if you have further questions.
Posted on Dec 18, 2008
onthejob5130
  • 640 Answers
SOURCE: Estate TAWS800JQ Top Load Washer
broken motor coupling
Posted on Dec 27, 2008
wiringlunati
  • 576 Answers
SOURCE: ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT
Check if the belt is good and tight enough. If that washer uses a spring tensioner on the belt, make sure it travels freely and applies sufficient tension.
Posted on Jan 01, 2010
Testimonial: "very appreciative of the immediate response and suggestion from Guru, i will try my best."
Hello, what is the capacity of Kenmore washer 110.28803890 in kilograms? Thanks
As a rule of thumb, 12 pounds of laundry is appropriate for a standard capacity top load washer, 15-18 pounds for a front-load washer, and 20-22 pounds for an extra large capacity front load washer. 1 lb.is .4536 kg so 15*.4536 is 6. kg. 18*.4536 is 8.17 kg.
Mar 13, 2018 | Kenmore Washing Machines
Trying to figure out the washer capacity for model # 22622 100 from around 2002 or so
suggest you check with the manufacturer's website . model numbers do nothing for us
Aug 30, 2017 | Washing Machines
GE WBXR1060TAWW, Top loading high capacity washer. I need the specs, capacity and number of speeds?
The (X) in the model number stands for extra large (2.7cu ft) capacity. The 1 stands for single speed. The 6 stands for 6 cycles. It should have a white plastic clothes basket. More expensive models had a stainless basket. Hope this helps you.
Apr 15, 2015 | GE Washing Machines
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
ESTATE TOPLOAD WASHER MODEL#TAWX700JQ3, DOES NOT SPIN FAST ENOUGH TO EXTRACT SUFFICIENT WATER FROM CLOTHE
Jan 01, 2010 | Estate TAWS800JQ Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
115 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
