Question about Microwave Ovens
I turn the dishwasher on to run and after two minutes the washer stops and the EO1 massage comes on.
  • Mark Lawlis Mar 18, 2011
    Bosch Model SMS63M08AU
    Bosch sms63m08au
  • 4,323 Answers
Hi
Please post back with the manufacturers name and model no of the dishwasher for further assistance.
Daniel
Posted on Mar 18, 2011
  • Daniel Scott
    Daniel Scott Mar 18, 2011
    Thanks for the information....E01 in
    your Bosch Dishwasher means that the machine is not getting water because
    either the inlet filters are clogged or the water inlet valve is bad. Try
    cleaning the valve first if the issue returns then the water inlet valve should
    be replaced. Hope this helps...please post
    back for further assistance.
    Daniel
    Thanks for the information....E01 in your Bosch Dishwasher means that the machine is not getting water because either the inlet filters are clogged or the water inlet valve is bad. Try cleaning the valve first if the issue returns then the water inlet valve should be replaced. Hope this helps...please post back for further assistance.
    Daniel
Kenmore elite microwave 79203 buzzes when off
It sounds like you have a shorted cook relay on your control circuit board.
That can usually be repaired more economically than replacing the circuit board.
Jan 09, 2013 | Kenmore 79203 Elite Stainless Steel 2.0...
Dishwashing tablet (the cleaning aid) stays dry during whole cylce.
The large arm that circles the top part of the washer should spin freely. I suspect a knife or fork has slipped and stopped it from turning.
Hope that helps.
Feb 27, 2011 | Microwave Ovens
Washer is making loud noise while running. It is also not cleaning the dishes very well. any ideas? Thanks
When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 18, 2010 | Microwave Ovens
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
I would suggest calling the seller or distributor and having this unit replaced.
This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
1)
LE ERROR CODE
YOUR MOTOR RING CAME APRAT
THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
2)
I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
Please rate my help++++Thanks for using FIXYA
Nov 16, 2009 | Microwave Ovens
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Runaway microwave oven
I'm wondering how old this is? There should be a date on the model number tag, or an FCC IC number on the label I could look up if you can supply that. You may have a defective control panel assembly. We routinely repair these nationwide for $32.50, but I'd be interested in how old you think this is. Does it do this when the door is open? I really doubt that it's actually cooking when it comes on, but it is possible. If the door is open, that should prevent it from happening. Only a temporary stop gap, though. Another way to find out if it's really cooking when it comes on is to place a cup of water inside. After it has run by itself a couple of minutes, check to see if the water is warmer. Besides the control panel, it might be the upper door switch or mount. You can do a Google search for my text file "doorsw.txt" which gives you good safety info and tips on how to check and replace defective door switches. Let us know what you find.
Oct 17, 2006 | GE JES1039 Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
