I want to know why my computer tower would beep once in awhile
  • 282 Answers
It could be a loose memory module,try reseating your memory modules
Posted on Aug 02, 2008
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
The computer does not fully boot when turned on, and the tower makes a continuous beeping sound. The monitor works fine, the problem is the tower. The tower just keeps on beeping without turning on or...
That beep could mean alot of things, but probably a VIDEO CARD or RAM has become unseated.
If you feel comfortable with this, UNPLUG THE COMPUTER take off the case, remove and reinsert the ram chips, and the cards. You might need a screwdriver or two, and a LIGHT. The ram tabs are small.
Good Luck
Nov 25, 2010 | Microsoft Computers & Internet
My computer is beeping and the green light is staying on but the red light is not on and it just beeps i changed the battery and still beeps and no signal
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Computer and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Nov 22, 2010 | Computers & Internet
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Scanner beeps. Laser is a dot instead of a line.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Computer tower started beeping
If you added more memory this may make your tower beep.
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
We have a computer tower that needs to be fixed. we got it from our neighbors that were gonna throw it out. it can still turn on but all it makes is a humming noise, then it acts like it's gonna start up...
Sounds like to me that either you're missing a bootable OS or its the harddrive. If it beeps, chances are the OS. You can buy a copy of Vista and have someone install that for you or you can do it yourself. But if you are nervous about such or dont know about computers, have someone else do it for you.
Dec 31, 2008 | Intel Computers: P4 3.0GHz Mid Tower...
Shuts down and beeps
The first place i would look is for an improperly seated ram stick or add-in card, also checking all the cables ( both data & power) inside the case.
Then i would inspect the system memory to make sure they are completely compatable.Take the two screws out of the back of the side cover and remove the side from the computer and physically inspect everything i mentioned above.
This is step ONE, dont rate yet , there will be step two and three ime pretty sure..
Oct 20, 2008 | E-Machines eMachines Desktop PC
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
