Question about Dyson DC28 Animal Bagless Upright Vacuum
Brushroll not turning on dyson dc28, how do you check the drive belt have removed the bottom plate but still can't get to the belt?
SOURCE: dyson dc17 animal
on the bottom plate are 3 spots, one in the center and one at each corner, that need a flat head screw driver to loosen. turn left to unlock, this will remove the plate so you can clear the debris from the brush.
Posted on Feb 01, 2009
  • 124 Answers
SOURCE: dyson make noise after replacing brushroll
Try this open sole plate check make sure belt is not pinched, broken or binding, that thee are no strings or hair between belt & roller,& that belt it is centered on roller.
Be careful & turn roller by hand should torn smoothly except for belt tension.
Also check make sure end bearings are seated correctly. (the parts at the end of the roller where they go into housing.)
Hope this helped. Please rate. If you need more help comment back be happy to assist you further.
Posted on Mar 14, 2009
  • 61 Answers
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
Posted on Apr 15, 2009
Vac Belts
  • 701 Answers
SOURCE: My dyson DC07 upright vacuum makes a loud noise
Did you check the roller brush to make sure it was clear of debris?
Posted on Nov 28, 2009
SOURCE: How do I remove brush bar to clean the housing
area of trapezoid
Posted on Apr 17, 2010
How do i change the belt on a hoover model #U4509
Lay the unplugged vacuum upside down and remove the bottom plate covering the brushroll to remove the brushroll and belt. Make sure brushroll bristles aren't worn, replace it also if needed. Make sure brushroll will spin freely. Put new belt around motor shaft then around brushroll. Pull on brushroll with both hands to get enough leverage to stretch the belt far enough to drop the brushroll in place. Put bottom plate back on and insure brushroll will turn by hand before you turn it back on..
Nov 12, 2016 | Hoover Vacuums
Dyson DC28 wont come on after cleaning filters
Support for DC28 Animal - Dyson
www.dyson.com/support/dc28/dc28-animal
DysonGet expert help for your DC28 vacuum from Dyson Support. ... as usual · Mini turbine head not working properly · Machine won't switch on or turns off on its own ...
How to Clean a Dyson Vacuum - Ask Anna
askannamoseley.com/2011/02/how-to-clean-your-dyson/
Feb 1, 2011 - Today I'm going to give you a tutorial on how to clean a Dyson vacuum. ... After you do a quick rinse take a washcloth and some dish soap and wipe the ..... My hubs will be so happy that I won't be paying someone to do this. ..... I have come as far as cleaning out the filters and will do the traps later today.
Amazon.com: Customer Discussions: Dyson Clogging/ loss of suction: Fix
www.amazon.com/forum/dyson/Tx2SY4FCNIUYI73
Amazon.com, Inc.Sep 25, 2009 - I can't veryify all canisters come apart the same exact way, but the problem ... That being said, you can clean your dust filtration unit and it is easy to do. ... using air or water won't clean the dust filtration canister while it is together. ... After2 years, my Dyson DC17 has lost suction in the upright mode, but the ...
DC28 Cleaner Head Replacement Removal - YouTube
? 17:19
https://www.youtube.com/watch?v=yERbv8owKU4
Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
My beater brush isnt rotating and I am sure I cannot check the belt by myself after looking at this video. ... I have ..
Jan 24, 2016 | Dyson Ball DC24 Bagless Upright Vacuum
HOW TO CHANGE A BELT ON A MC-V7305
Make sure vacuum is unplugged. Lay. Vacuum upside down and remove Bottom plate. Pull brushroll from nozzle housing, pull metal end caps from brush and remove any hair and debris. Put new belt around motor shaft then around brushroll. Put one hand on each side of belt and pull brushroll to stretch belt far enough to drop brushroll into position. Make sure brush spins freely. Install bottom plate. Make sure brushroll turns freely, if not, make sure bottom plate is not restricting the belt before you turn the vacuum on. Repeat the process in 6 months. You may be surprised to see how much a belt stretches and loses elasticity after it's been on your vacuum for 6 months.
Feb 08, 2015 | Panasonic Vacuums
So the beater bar on our dyson DC28 animals to starts to turn then stops. Is there a video or schematic break down out there? Would like for reference for dismantle and rebuild. Thx, Mike
The beater bar on his machine and other dysons dc01,dc07,dc14 is directly driven by the main vacuum motor via a rubber belt(some models have safety clutches). There are no reset switches- the three tabs on the base are to allow removal of the sole plate. If something jams in the beater while operating and left for long enough (about 1 minute) the belt can burn out and need replacement. the belts are cheap, good skill is required to remove the sole plate to install a new belt because they are so tight.
Dec 20, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Replace belt on DC 14 animal DYSON
Remove the bottom plate, then the brushroll and clutch cover. Remove the clutch and disassemble it to gain access to the belts. There are two belts in the clutch.
Jul 29, 2014 | Vacuums
Simplicity F3500-- how do I get the bottom off to change the belt?
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
Beater head makes loud noise on 'carpet' mode
Possibly a belt problem, but more than likely a brushroll problem.
The bearings are cheap and nasty, and are prone to siezing.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 29, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cant replace a belt to a dyson dc14 all surfaces.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567059
Generic problem for all Vacuums
Can’t replace a belt to
Posted by hegarty01 on May 03, 2008
Can’t replace a belt to a dyson dc14 all surfaces.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You need to remove the bottom plate of the vacuum and then lift up the pulley side of the brushroll and then take off the old belt and install the new belt the replace the brushroll. Then take a belt puller or a screwdriver with a bend on the end and pull the belt onto the motor pulley and then track the belt in a straight line. If you have a problem with the belt change then refer to your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/
Dyson Inc. 600 W. Chicago Suite 275 Chicago, Illinois 60610
Customer Service 1-866-693-9766 questions@dyson.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Vacuums
How do i change the brushroll belt on the mce480 vacuum cleaner?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.1st tune your vacuun over to expose the bottom plate and the brushroll / belt area,
and the bottom plate is held on by either screws or clips, remove the bottom plate and tkae of the belt. When you install the belt, place the belt on the brushroll pulley 1st, then if you have a screwfriver with a bend or hook on the end the pull the belt onto the motor shaft then roll the brushroll/belt so theat it makes the belt run straight. Place the bottom plate on the unit and turn it on to make sure the belt stays on and then put in the screw or clips to secure the bottm plate.
http://www2.panasonic.com/consumer-electronics/shop/Home-Appliances/Vacuum-Cleaners/Upright-Vacuums.list.75100_11002_7000000000000005702
Customer Service 1-800-211-PANA (7262) Panasonic Factory Customer Service
Apr 10, 2008 | Vacuums
Dyson DC28 Animal Bagless Upright Vacuum Logo
1,114 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
