Question about Avanquest Fix-It Utilities 11 Professional for (Pc)
I want to install Fix-it-utilities 11 on my computer. I get the message saying you can not install fix it utilities 11 until you uninstall fix it utilities 10. I went through the control panel and tried to remove fix-it-utilities 10. I then get the message a patch is missing from fix it utilities 10 and that it could not be uninstalled. Thanks for your help. Mark
    Sergeant:
    Champion:
  • 236 Answers
Sounds like it was partially uninstalled. If you are knowledgeable with using the registry you can go into it and remove any instances of this utility.
Posted on Mar 18, 2011
Installed program fix-it-utilities on window 7 computer will not run
just uninstall and use this program: http://www.4shared.com/rar/cSpGDv9C/auslogics_boostspeed_v5500_por.html
Aug 24, 2014 | Avanquest Fix-It Utilities 11 Professional...
Can not open fix it utilities professsional
The cure for about any non-working software, including operating systems, is to uninstall it, and then re-install it. After you reinstall it, restart the computer, close all open programs, and then try to run it. If this fails, start the computer in safe-mode, and then run it. Also, some virus' disable pc-repair/anti-virus tools. Good Luck to You.... :)
Apr 04, 2014 | Avanquest Fix-It Utilities 11 Professional...
Cannot uninstal fix it utilities 10
You can go ahead and install the program revo uninstaller pro using the link http://c464521.r21.cf0.rackcdn.com/RevoUninProSetup.exe
Using which you can go ahead and uninstall the fix it utilities program from your computer, you need to select the hunter mode and point the short cut icon, if the program is not listed under the uninstall option in revo uninstaller.
Jun 18, 2011 | Avanquest Fix-It Utilities 10...
Cannot re- install fix it 10 tells me a version of fix it needs to be removed first when i try to uninstall it tells me it cannot find " installation package" ( WIS5158ect...) Even when i try...
Hi headshotbill
Install RevoUninstaller from http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Select the advanced method ( point 4 ) and when you get message " cannot find installation package "
, ignore , click next for a full registry cleaning . It's all automatic and free .
When done , you will be able to install your program .
Best regards ,
fanaudi .
May 30, 2011 | Avanquest Fix-It Utilities 10...
I uninstalled mcafee keeps saying i have to uninstall won't install program
hi,
you can try to exit the program or stop the program before yout try to uninstall the program.
Hope this one helps.
Thanx
Apr 04, 2011 | Avanquest Fix-It Utilities 11 Professional...
I cannot play my games after i reformat my computer. its say that i need an directx 8.1 or higher to play my game but i already downloaded directx 11 but is useless. nothing happens. same error message...
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
If it's a ntdll.dll error the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
don't forget to vote
when you restart your computer then defragment your hard drive
you should not do anything while the chkdsk utility is in progress any imput may damage your computer also do not start if there is a possibility of a power failure (storm lighnining)
hope this helps
don
Feb 20, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I've downloaded Fix-it 10. It won't install until
Well in that case go to the Program Dir find the Folder it is in, and simply Delete the files, delete them all, then remove delete that Dir, Now try a reinstall. Either that or in that Directory look for the uninstall exe file and double click on that and try that way first... else remove them all.
Feb 19, 2010 | Avanquest Fix-It Utilities 9 Professional...
Unable to uninstall Fix-It Utilities 8
Use REVO uninstaller. It is free and good uninstall utility
Dec 13, 2008 | Avanquest Fix-It Utilities 8 Professional:...
Driver blockt work due to compatibility issues.
A user can uninstall the Windows Vista update that is causing this issue. Once the update is uninstalled you will need to wait until Microsoft has released a fix for this issue. Otherwise, a Windows Vista update may cause this problem to occur again if Microsoft has not pushed a fix yet.
To uninstall the conflicting update, do the following:
1. Click Start
2. Click Control Panel
3. Click Programs and Features
4. Choose View installed updates
5. Select "Update for Microsoft Windows (KB943302)
6. Click Uninstall
7. Restart your computer and the update should be uninstalled
Jan 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Can't install
What is the error message????What it says???
Aug 30, 2007 | Symantec AntiVirus 9.0 Enterprise Edition...
Avanquest Fix-It Utilities 11 Professional for (Pc) Logo
330 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Tarpan Shrivastava
Tarpan Shrivastava
Joseph Hoffmann
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
