Question about Invacare Supply Group 10" x 3" Foam Filled FlatFree Tires for the Invacare Pronto M71 Power Wheelchair ()
I have an Invacare M71 Pronto and the I am having a hard time with the on off button on the joystick control. I had it cleaned and the two gold covered pads directly under the on seem to be dark. Where can I order that circuit board so I can replace it? I have found the keypad but I belive I want to change the PCB also because it the keypad has some small holes in it at the on off button.
  • 692 Answers
No need to replace the circuit board just take a pencil eraser and rub the gold contacts to clean them making sure that you clean the residue after cleaning. the faceplate buttons have a metallic coating under the button and over time will wear off. You can glue a small piece of foil to the bottom off the buttons and the switches will work fine Since you have already purchased a new faceplate you can install it or you can glue foil to the bottom of the on/off button of the old faceplate and keep the new for later if you need it. Hope this helps you
Posted on Mar 19, 2011
Pronto M94. Why doesn't the power button shut off?
The buttons on the joystick wear out on the bottom of the button. The bottom of the button has a conductive material that touches a circuit board. The buttons can be replaced. The buttons are all one big sticker than can be peeled off and a replacement stuck back on. Do not remove buttons until you get what Invacare calls a Joystick Overlay. Invacare will need to know the exact joystick to get you the correct Overlay.
Sep 01, 2015 | Invacare Health & Beauty
No lights on joystick
Here is a parts catalog for the M41. http://www.invacare.com/doc_files/06_108.pdf
If it was working fine before you swapped the batteries then you did something to interrupt the current flow. Pages 49/50 show the location of the controller with a picture. Unplug the connections here and make sure they are clean and in good shape. Make sure all other connections are clean and tight.
If you have 24V coming off the batteries into the controller, and 24V going out to the joystick from the controller and still nothing is working, then you will probably need to get ahold of an Invacare service tech to replace the joystick. Before he does that he should swap out the old joystick with a new one to see if that is the issue. Invacare parts are pretty pricey...joystick by itself is over $500.00. If the controller is shot, then you can double that cost. Sometimes, both need to be replaced as they can kill each other.
If the chair is old or has a lot of hard hours on it, you can usually shop around on Craigs List, etc and find a good newer/near new chair for about the same price as a new joystick replacement.
Feb 23, 2015 | Electric Mobility Invacare Pronto M41...
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
Jul 08, 2014 | Invacare Supply Group Invacare Pronto M91...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
I have invacare pronto m51 with surestep the spjis flashing 9 times what is the problem
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Nov 19, 2010 | Invacare Pronto M51 Power Wheelchair
Acs typh. invacare electric wheelchair, red light showing hand controls locked, cannot unlock it. please help asap.
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
Aug 14, 2010 | Invacare Pronto M51 Power Wheelchair
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
One of my residents has a Pronto M91 Sure Step and it turns on, the horn button works, the speed buttons work, but it WILL NOT turn off. Please help me. Would that mean I need to change the joystick...
just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
Jul 30, 2010 | Invacare Supply Group Invacare Pronto M91...
Will only work at a slow speed, speed control has
The joystick sounds like its off alignment,Once knocked off alignment it will have to be replaced .
hope i was able to help
May 17, 2010 | Invacare Supply Group Invacare Pronto M51...
Invacare Supply Group 10" x 3" Foam Filled FlatFree Tires for the Invacare Pronto M71 Power Wheelchair  () Logo
127 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
