Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
We misplaced the original cord and tried another one that ended up being too high in voltage. Now we found the original cord - but the WD my book will not show up the computer. The blue light flashes for awhile. But nothing comes of it. Is this the end of the harddrive?
    Master:
  • 525 Answers
You may have fried the power supply. Try taking the hdd out of the case and intalling in into a desktop computer.
Posted on Mar 19, 2011
My wd hardrive wont power on
look at power pack and look for the polarity diagram. get a multimeter and test the power that the pack is providing and make sure it is outputting what the pack says it is supposed to. if the pack is not at correct voltage, then this is most likely your problem. find another pack (MAKE SURE VOLTAGE AND POLARITY ARE SAME!!!! if voltage is correct but polarity is backwards, cut cord and swap wires before post to change it, or find another pack.) If the power pack checks out, then you need to open the WD case up and inside you will find a standard desktop 3.5" hard drive. most likely sata. remove from case and install it in a desktop computer and see if it will power and mount. if it will then the circuitry in the WD case is bad. If hard drive will not mount or show up then the hard drive is bad. If The WD case is the problem check circuitry for bad caps, transistors and voltage regulators. replace as needed. or just keep the hard drive in your pc as a permanent upgrade.
Sep 18, 2012 | Western Digital My Book Essential 1TB...
The Western Digital hard drive My Book Elite does not show up on the computer screen when plugged in to the Mac computer. It has the blinking light that shows that it is thinking, and everything else...
hello
i have the same issue, exact same unit MY BOOK ELITE WD 500G ..
FYI: if this doesnt work, it is a power module (inside the black box, MY BOOK ELITE) needs to be replaced.
UNPLUG both cables from MY BOOK ELITE WD - restart your computer
- with respect to the MY BOOK ELITE WD , make sure the power cord is plugged into AC outlet wall only, and the other end of the USB into computer only -- but disconnect both from the MY BOOK WD ELITE and leave unplugged for 20 minutes .
after 20 minutes have elapsed, plug the USB cable only for 1 minute , into MY BOOK ELITE WD. Then plug the power cord into the MY BOOK WD Elite. see if it works
if this doesn't work, let the drive sit for 24-48 hours.. then repeat above instructions -- this is how i got mine to work again. FYI: To avoid this issue, i just leave the unit plugged in , while computer is running
BUT -- be aware... i use UPS (Uninterruptable power supply) to avoid power failures throughout the house. So , i suggest , if you want to leave the computer running, use a power supply to run the computer if the AC power fails..
please issue 4 thumbs up
Feb 04, 2011 | Computers & Internet
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Input Voltage on WD MyBook and Elements
NO, they are not all multivoltage. Especially if you bough *** in the states as a 110v. You will need to have an external voltage adaptor in use.
Jun 13, 2009 | Western Digital My Book Essential Edition...
I have a WD external hard drive and need a new power cord. model # wd2200h1u-00 where can I find one?
for those, you can use a generic power cable as long as the voltage and amperage matches the original one. Take the old one with you and head to a radioshack.
Jun 10, 2009 | Western Digital 320GB MyBook External USB...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
My book not recognized by windows
I had a similar problem that I just fixed. The drive was not being recognized at all - I unplugged, rebooted, switched to different computer, used different usb cable, plugged into wall outlet, NADA!
Then I tried something else - I just bought 2 more external hard drives and I switched the power port from the new one to the old one and the hard drive was recognized. I plugged the old outlet into the new hard drive and that worked, too. PHEW!
I had almost 100Gbs of music on there!
Dec 24, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
121 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
