Question about Zanussi F1245W Front Load Washer
The machine will not spin and there does not appear to be enough water in the drum when washing
    Problem Solver:
Will not Spin! Spin begins and then cuts out!
Pump checked OKI! Brushes checked OK! All tubes checked OK! Everything else works fine!
Posted on Apr 11, 2011
  • 360 Answers
This is a common problem and while it can be caused by a variety of malfunctions the most typical cause is a damaged lid switch. Look for a plastic pin attached to the bottom of the lid near the front opposite the hinges. The pin aligns with an opening in the top rim around the tub, this is where the switch is located. You can attempt to manually actuate the switch by inserting something (preferably non-conductive) like a plastic pen into the opening. This most likely will not work because the switch is probably physically damaged. To repair/replace the switch on most machines the chassis has to be removed for access.
Posted on Mar 18, 2011
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Leaks from top of outer drum when viewed with front panel off.There are a half dozen or so small openings around top of outer drum (maybe where outer drum hooks/clips onto inner drum) water was viewed...
There is too much water (or not enough clothes) in the drum. When it spins the water rises up the side of the tub and overflows. Use a lower water setting (smaller load size).
Jul 08, 2009 | Washing Machines
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Zanussi F1245W Front Load Washer Logo
105 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
