Question about Garden
I have a bolens bl150 gas trimmer and the problem is that it stards but won't stay running. it starts and it diey it starts and dies over and over again. what could be the trouble?
    New Friend:
  • 62 Answers
  • Check the fuel mixture and make sure it is correct.
  • Clean the air filter if needed.
  • If everything else is fine then you may want to try and adjust the idle speed screw. The screw is located on air filter/muffler cover.
Turn the screw "clockwise" to increase the idle speed. Only turn it about 1/8 of a turn at a time (as needed) until the engine runs smoothly.
If it still doesn't run properly then you may need to have the carb cleaned.
Bolens BL150 Manual
Posted on Feb 17, 2016
SOURCE: Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Posted on May 18, 2008
#1 Taper
  • 1041 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
  • 16 Answers
SOURCE: troy bilt 4 cycle string trimmer wont stay running
If this is an old unit, then the diaphragm is probably hardened.
Tests before hand would be:
1. Is the gas fresh and water free?
2. Is the spark-plug clean and snugly fastened?
3. Are you using the correct gas to oil mix ratio in your fuel?
4. yes...yes...yes...= bad diaphragm. Probably less than $5 for the part and a 1/2 hour to replace the part.
Posted on Jul 07, 2009
  • 51 Answers
SOURCE: my pull string came out and will not retract on my
the coiled rewind spring ends are bent back in a hook. the hook usually breaks so springdoes not wind up. some times you can re bend but steel is very brittle and keeks breaking and must be replaced
Posted on Jul 18, 2010
SOURCE: My ryobi bc30 trimmer runs but when I give it gas, it dies
I have the Ryobi BC30 trimmer, also. For a year now, it would only work on half choke. Putting it in run position would cause it to quit. Also, it would no longer idle...it would quit if I idled it for too many seconds. I had not used it in a long while. It would then not run in half choke position and would die in idle. I figured out that if I kept moving the choke lever between full choke and half choke, I could keep it running. I checked the internet for what would cause this. I was using NEW gas and oil. I had replaced the fuel tank because of a hole in it that nothing would seal. This means I had a new tank, fuel filter, and fuel hoses. So, this was not the problem. Since it runs fast between choke and half choke, the basics of the system were fine. I took the carb apart and cleaned whatever I could. Took out the little fuel filter screen and cleaned it. No difference. I took off the exhaust module and looked at it and the screen that is the flame arrestor (mentioned on the internet). It was fine. Of course, folks mention using carb cleaner spray into the air filter port (oh yeah, I had replaced the air filter with a new one earlier). Sprayed repeatedly and no difference.
So, here is WHAT DID WORK! Took the carb off (pretty easy (two nuts to remove, take off the two fuel lines, and remove the little wire that controls the throttle)). Now, take the carb apart carefully screw at a time...geez, there are only two sides! Be careful with the gaskets. One has a thick gasket and a thin one sandwiched together. Pry these apart and clean them (with the carb cleaner spray you already bought). Put them back together and lay aside. Take the other side of the carb apart (another couple of screws?). Need I say to lay everything you take apart on the ground in the order you put them back together? Now you have several big pieces of carb and several smaller plates from each side. Now take your carb cleaner can with the small red straw. Place the straw in EVERY hole you can find on the big pieces and small pieces. Either where goggles or some kind of eye protection. BLAST out all these holes until either fluid comes out ANOTHER hole or obviously this hole goes nowhere. If these holes spray out fine elsewhere, then spray it out backwards through those holes! Be sure to take the fuel filter screen out of its hole (you will just have to find this screen in a fairly large hole in one of the BIG carb parts). Clean the screen by spraying the carb cleaner into it until you are sure it is clean. Place the red carb cleaner straw into the screen filter hole right on the TINY hole at the bottom. Look at the reverse side of the carb. There is a mechanism on a rocker arm that moves up and down with a little push on a flat metal piece. This is the reverse side of where the big hole is that had the screen in it. Blast this out with the carb cleaner while pressing on and off of the flat metal bar on the reverse side. You will see that the flat metal piece is attached to a pole that disappears towards the large hole on the other side (the one that had the screen in it). While blasting from both sides, you will only get a little spray come through. Just keep blasting to clear this component. This is really the only tricky part to clean. ALL the other holes generally will either clear out pretty quickly or there is nothing in the hole. The idea is to BLAST ANY hole you can find in ANY of the parts. Like I said, be careful because while you are blasting TINY holes, you will get a good bit of blast back from the hole you are in. This will cause spray to hit your hands, face, eyes, etc. BE CAREFUL. Don't be a wimp, just protect your self. The carb cleaner is under pressure. It will come out COLD. If you have cuts on your hands, it might even sting. It will also DRY out your fingers if you get enough of this stuff on you. Either wimp out or keep going. If your fingers are getting too cold because of the over spray or back spray, or the carb is freezing, then back off for a bit. This is a disclaimer! Right now my fingers are VERY clean and VERY dried out (but my BC30 works fine!).
Ok, you have sprayed all the holes and figured out that any thru-holes is now clear. Put all the parts and gaskets back together. Reattach the fuel lines to the proper spouts, reattach the throttle control s-curve wire properly. Reattach the carb to the unit with the ONLY TWO nuts. You are now all together again with a really clean carb.
Fill the fuel tank with FRESH GAS from the gas station with the proper oil mixture (come on....just buy the small oil bottles that you use the whole bottle per a gallon of gas).
Ok, you are now starting out with what ought to be a VERY clean carb. THAT problem should be over! What may not be over is that the idle and the high speed may not be working. Remember that my unit would not idle...it would cut off at idle. This procedure cleaned that right up!!!!!!!!!!! The other problem was it would ONLY run at half choke and then less than half choke. Run position would stall and stop.
So, now you need to start the blasted machine. I tried using the proscribed method using FULL choke for a bit, and then half choke. I had waited awhile letting the carb cleaner to evaporate. Don't know. It did not want to even start for awhile. SO, I tried to get it to start in the manner that was working BEFORE I started all this junk. I put the lever in a position between full choke and half choke. This was a very hard position to maintain in order to keep the lever from moving. I had to press the fuel bulb a few times every now and again. I was pressing the FULL POWER button. All of a sudden, it started. And what to my surprise, when I took my hand off the throttle, IT STAYED running! This was PROGRESS!
Now, I put the lever in half choke position and pressed the throttle button. It cranked right up! I was at least back to where I was a year ago. When placing the lever in run position, it tried to stall out as it did a year ago. That was ok, I was making progress. I fiddled around a bit keeping it running and ascertaining that in half choke mode AT IDLE, the unit STAYED ON also at full throttle. I am stoked because I feel the carb is fully cleaned and none of the holes are clogged. So, NOW I feel the only problem is the screw that controls the jet of fuel when the unit is in RUN mode is the problem.
MY UNIT has the TWO screws on the side of the carb. The one closest to the engine controls the IDLE speed of the unit. Since, my machine now idles without cutting off, this screw must be adjusted fine. This also means that one of the holes that deals with the idle was clogged...and my efforts of blowing out ALL the carb holes has fixed this problem. The screw that is FARTHER away from the engine controls the HIGHER speed which includes the RUN position.
So, I took a flat head screw driver to adjust this screw (the OUTSIDE screw). I started the machine in the HALF-choke position that was WORKING. I then turned the outside screw COUNTER-CLOCKWISE a quarter turn. I then moved the lever to the RUN position. It STILL RAN! WOW! But then, as I revved the engine up and down, it slowed down a bit and made me think it might quit. Put it back in half-choke position and it ran fine and revved back up. I then adjusted the outside screw some more in the counter-clockwise position and went back to the RUN position with the lever. I am making progress. I reached a point where I could leave the lever in the RUN position and kept adjusting the OUTSIDE screw counter-clockwise until the unit would go from idle to full speed in the RUN position without stalling or sounding funny. The end result was that the full power was operational and when I let the throttle go, the unit revved down but kept running fine.
My RYOBI BC30 now runs just as well as it did when I first bought it. I did NOT have to buy a new carb OR a carb kit! I was careful with the existing gaskets (one gasket was broken on the OUTSIDE of the screw it went through but had no effect (the outside was far enough away from the inner important area)).
So, here is the deal. If your Ryobi BC30 only runs when you have it set on half choke or less instead of the RUN position (BUT IT RUNS), then your CARB probably has some plugged up holes in it. If when in idle, it quits, then some hole(s) are clogged. The fix is to BLOW out these holes! I used carb cleaner over and over again until I felt the holes HAD to be clean (spray easily came out somewhere else). Some people say to use canned air to clear out the holes. I had the carb cleaner but not the air. So, I did it with the carb cleaner pressure. This worked.
I must say that EARLIER in my trouble shooting actions, I found bits and pieces of what I figured were bits of gasket material which I removed early on. When you take the two nuts off those LONG two screws that hold the carb to the unit, it is hard to remove the plastic air filter unit. Because of this, it is possible to strip some plastic off the air filter unit that might get into the system. So, be careful here. I had to force the plastic unit off...it simply was very tight...so be aware of this. It was so tight, that I looked many times to see if there was something else holding on to it.
Last deal. You can clean the carb. You can adjust the screws if your unit has them. I have heard that later modules do not have the idle adjust and high speed adjust screws. If yours does not, then follow my directions to clean the carb. I have no idea what to do about the screw adjustments if your module does not have the screws. Troup Nightingale
Posted on Jul 31, 2010
Repair manual for bl150 bolens gas trimmer
Request the repair manual from Bolens.
Dec 09, 2017 | Garden
Bolens manual
http://www.freeproductmanual.com/bolens-bl150-manual/
Aug 17, 2014 | Heating & Cooling
Ryobi 780 r won't stay running
replace the carb. You are flooding the engine because there is an internal leak that a carb kit won't fix allowing the gas to continue to flow
Feb 01, 2013 | Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
Restring bolens bl150
There are two ways to re-string a weed trimmer.
  1. Wind new line on the inner reel
  2. Install a prewound inner reel
Check the owner's manual below for detailed instructions.
Bolens BL150 Manual
Mar 31, 2012 | Garden
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
1,146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
