Question about Lexmark Office Equipment & Supplies
I have changed my internet service from comcast to verizon and I cannot get my lexmark printer 3500-4550 to print out any thing that I print from my computer.
    Sergeant:
  • 206 Answers
Internet providers don't have anything to do with printing documents to a printer. Are you sure the printer is installed correctly? Try turning the printer all the way off...then shut the computer down. turn the printer back on...once the printer has gone through all of its startup processes then turn the computer back on and try to print again. if it still doesnt work, go to start, control panel, devices and printers and make sure the printer is showing up with a checkmark on it. Otherwise, post back and we will try other measures. Good Luck
Posted on Mar 18, 2011
I have a Canon MP730 MultiPass. I have always been able to fax, until recently. I noticed my inability to fax after switching my service from Verizon to Comcast, although I am not saying this is the...
If your Comcast service is DSL, you may need a DSL adapter to work with older analog telephone devices, like your fax machine. You should be able to find them readily available at $10-$15.
Aug 27, 2009 | Canon Office Equipment & Supplies
When trying to send a fax I keep getting phone line errorand when i print from the internet the text comes out as gobblygook
If you have you phone service thru an internet provider like Comcast, or Roadrunner, typically speaking, anything other than a POTS system with analog copper wires can be the problem. (i would have referred to this as a VOIP system, BUT, CABLE AND ISP PHONE SERVICE ALTHO IT IS A DIGITAL TRANSPORT, IT IS NOT TRUE VOIP).
Here is your fix--- set your baud rate on the fax to the lowest setting, usually 1400 bps. If you dont know how to do this consult the owners manual, be aware, not all fax machines are capable of baud rate adjustments.
Jun 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark 1235 (OLD), it is not compatible
Below is a link that is untested but is advertised as being a Vista driver for your printer. Feel free to try it and see if it solves your problems. Best of luck.
Greg
http://greg.margo.home.comcast.net/x125vista.zip
p.s. Please post back with results if you try it; there are many with the same issue and I'd like to help as many as I can.
May 11, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
(janddgasrepair@verizon.net)
Don
Apr 07, 2009 | Lexmark T630 Laser Printer
Lexmark x2600m printer not queueing
The best Solution for this would be goto Start click on Run type in Services.MSC and click ok now on that window u will see an option saying print Spooler just restart that by right clicking on it......
now go to control panel and go to the Printers Folder......
Right click on the Printer Icon and click on Properties......
Now click on Advanced and then go to Print Processor.......
It will be by default on Lexmark LEMF change it to Lexmark NTEMF 1.008......
Click on Apply click ok......
Restart your Computer and try to use it it should work......
Good Luck...........
Jan 09, 2009 | Lexmark X2500 All-In-One Printer
Lexmark all in one series x6570
Remove your printer first and uninstall driver .Then set your ip address, dns and gateway in the computer as given by the internet service provider. And connect to the internet. Then connect your printer and install drivers. If your printer is ok then it should work
cheers
May 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Lexmark 4270 won't print
To resolve this, download Internet Explorer 4.01 Service Pack 1. For more information, please refer to article Q185959 from Microsoft.
Note: Please check to see what version of Internet Explorer you are using. If it is higher than 4.01, contact Microsoft for an update.
Mar 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printing from computer
check the cable connections and re-install the driver/software
go to lexmark website and get the latest driver for your operation system.
Also when you print, make sure you are printing to this printer
print from word-pad or any other program OTHER than internet.
Jan 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
I CANNOT GET MY LEXMARK Z53 TO PRINT ANYMORE
O.K. first go to
-File
-Print
-Porperties
do you see your printer there? is it highlighted? does it have a checkmark?
if it's not there then you have to install it in Printers and faxes add a printer.
If if not highlighted then right click on it and "set as default"
then place your mmose over it and see if it says "ready" or offline
if  it's offline then the connection is wrong, leave mouse over printer and change connection it should change to 'ready"
Oct 12, 2007 | Lexmark Z53 Color InkJet Printer
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
