Question about Kodak C195 Digital Camera
I dropped my camera now whenever i turn it on it say 'lense obstructed how do i fix it???
  • Kodak Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Mar 18, 2011
Does the Nikon S8100 seem to have more lens error problems than other cameras?
Not really. It's extremely common on all similar designs from all manufacturers which have retracting/zooming lenses. The trick is to try and prevent the lens from ever being obstructed and to keep the camera in a camera case whenever it's not in use. Also avoid sand/beaches or similar areas as the camera isn't designed to cope with dirt which can get inside due to wind or being dropped.
None are robust, if they fail under warranty they get fixed or replaced. Outside of that you either fix it yourself or bin it and buy another as professional repairs usually cost more than buying another model.
Jun 20, 2011 | Nikon S8100 Digital Camera
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
Camera got dropped now it won't turn on.
The only way to sort it properly is to dismantle and reassemble. Because it has sustained damage you will have to check for any internal damage caused by the drop. Now the lens is jammed open would suggest the guide pins have either come out of their slots preventing movement or something is obstructing them.
Jun 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Jammed Lense)
Make sure the lense is not bent. If so, gently straighten it. This worked with mine.
Nov 28, 2007 | HP Photosmart R717 Digital Camera
Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Sep 08, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Kodak C195 Digital Camera Logo
215 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
