Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I need to scan a document and the computer says it does not "find" my kodak all in one. I have lost the disk to it but have had this machine about six months and its worked fine. laughingmoose2@yahoo.com
  • 93 Answers
Download the driver of this all in one at http://support.en.kodak.com/app/answers/detail/a_id/32108/selected/true.
Reinstall your Kodak ESP 3 all in one.
Posted on Mar 19, 2011
Scan document to PC
Make sure you have the kodak software installed and go to the "kodak AIO center" (download it if you don't have a disk) you should see an option to scan an image.
Dec 05, 2013 | Kodak ESP 5 Printer
I have a Kodak ESP5210. Its an all-in-one with the printer, copier, and scanner. I can't get my scanner to work. I put a picture on it and hit "Start" and all it did was keep saying scanning. It...
Make sure any other scanners are disconnected from your computer. I had a problem with the scanner in the Kodak ESP 7 AIO printer. Kodak advised me to disconnect my other scanner. After I disconnected my Canon scanner, I was able to use the Kodak ESP 7 scanner.
MWR
Feb 28, 2011 | Kodak ESP 5 Printer
I upgraded my computers operating software from Windows Vista to Windows 7. When opening the HP Solution Center/Scan Document, I lost the Scan Shortcut: "Document to E-mail". My question is, how...
Hello;
hope only shortcut lost not the program, click windows start>then pointing all programs(you can see all programs installed in your machine) navigate to hp solution>right click the scan document>click sendto>then select desktop(create shortcut)..goodluck!!
note;in other programs when you right click is diffirent,(click the create shortcut)
Feb 21, 2011 | Computers & Internet
I have been using it for years, suddenly starts to present an add same "There is not enough free disk space to complete scan..." What is it? What can I do?
Hi
Scanning require disk space in you computer. Try to remove some clean up or remove some document files in your hard drive to free some space. Check also your C and D drive jf how much disk space it available.
Jan 13, 2011 | Canon CanoScan LiDE 500F Flatbed Scanner
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I attempt to scan pics or any document to my computer, the display reads "No scan options. Refer to device documentation to troubleshoot." Of coarse, I lost my user's manual in my move. How...
You need to scan another way
On computer click Start >>>> click Programs/All Programs >>>> click HP >>>> click 'hp solution center' or 'hp director' to open it >>>> click "scan a document" >>>> click "scan" >>>> click "finish' or 'accept' to complete the scan
If above programs are not there, it seems full software is not installed in computer. You need to install full feature software through cd
Dec 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
I've lost my set up cd and although the printer and copyer work I cannot scan a document onto the computer.
Scanning a document to your computer may require the Lexmark OCR scan software which is only available in the installation disk. Try to contact Lexmark technical support to request for the installation disk. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X4650 InkJet Printer
Lexmark 5600 how can a I scan or make it a word document or pdf file
You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
My scanner won't scan
Check that all the needed drivers are installed for your scanner.. If the computer is able to detect the scanner it should scan..
Follow the steps below
Step 1: Open the Kodak AiO Home Center software (make sure to upgrade to the latest version) (hyperlink "version" to http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7895&pq-locale=en_US)
Step 2: On the home screen, select "Scan Documents and Pictures”
Step 3: On the Scan screen:
  1. Select "Document" and "Black and White" and be sure that Perfect Page Technology is applied (it's selected by default for document scans)
b. Click "Next"
Sep 07, 2010 | Kodak Office Equipment & Supplies
My printer prints and copies but doesn,t scan
scanning requires a place to keep a copy of the document.connect ur computer and printer via usb2.0 and then open kodak home center from ur desktop. from there scan the document. u will be able to scan and keep a copy of the document on the desktop. if there is any problem,contact kodak @ 1800 421 6699
Jul 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
