Question about HP Office Equipment & Supplies
The printer is not connecting to the pc - HP Office Equipment & Supplies
    Genius:
  • 1,570 Answers
Hi
Please try this
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Posted on Mar 18, 2011
  • Benjamin Jr Singson Mar 18, 2011
    What do you mean by not connecting? check the printer icon if it is offline or cannot be set up to connect the printer?
Can I make my printer wireless? If so, how?
Yes. Sell it & buy an Epson L355 (if available in your country) Or get someone to buy for you if not.
Integral Epson ink tanks, heaps of ink, very reliable. Googlit.
Jun 29, 2014 | Epson Stylus Photo R300 InkJet Printer
Connecting Dell Dimension 5150 PC to HP Officejet Pro L7580
uninstall all printer software and drivers then restart w/o the printer connected. install the software 1st when it checks 4 printer thats when u plug it in.Also check your ink cartidges. what is the model of printer?also update your drivers .in your boot up is usd devices part of your boot? that would be in your bios settings.did you have a printer before?need more info.
Feb 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My windows pc is not detecting my lexmark z600 printer
How do you have it connected to you PC Ethernet, USB, Parallel cable? Check your connections. I am assuming it is USB since you have no internet connection at home. Go to your printer settings and see what port it is connected to. If it is a USB make sure it points to that connection in the panel.
Jul 24, 2012 | Lexmark Z600 InkJet Printer
How to connect an hp printer to a compaq presario
Hi Sean,
How do you want to connect your printer to PC ?
Please provide the below information ?
What is the operating system on your PC ?
How do you want to connect your printer ? via USB or Wireless
If you are using Windows 7 PC, you dont need drivers for your printer as HP does not have it designed,
You can connect your Printer to PC thru USB Cable directly and the drivers will be loaded.
Regards,
Suhail
May 14, 2012 | HP PSC 1210 All-In-One InkJet Printer
Reboot printer 061-370
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Oct 17, 2011 | Fuji Xerox® DocuPrint C3055DX Laser...
Computer says hp 6210 is offline
Make sure your printer is on.
Then check your connection between your PC and your Printer. Make sure your connectors are not loose.
If nothing happens, try restarting your printer together with PC.
If its not able to detect check your connections with your printer by clicking Windows icon then "devices and printers".
Once there right click on printer icon and see if it is enabaled.
If your Printer connection is actually connected to another PC or in other words in a network. Make sure that the PC that the printer is connected to is on.
Good day.
Jun 19, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Use of HPJ4680 in a network with Mac & PC connected to router
Ok what you do is, install the printer as a LOCAL one on one of the PC's, Probably the XP, one, would be best. or perhaps the PC; actually "Connected" to the D-link router & Modem, then Now install this printer , as a LOCAL, printer, and set as DEFAULT, enable Printer Sharing. Now, ALL PC's MUST, have a Name, Belong to the same Workgroup, have a Password. On the "Other" PC's Install the Printer as a Network Printer, browse for it and connect. Print a test page from each. Remember the PC with the printer attached, must obviously be ON or the "Others" cannot connect and print.. Make sure all network permissions are set sharing is set, especially on the Win 7. Just make sure they can all "See" each other first, before try all this.. the network MUST be intact and communicatable from each PC to at least the PC with the printer attached. I have included 3 links below, to help
kb.parallels.com/4886 - support.apple.com › Support -
support.microsoft.com/kb/239418
Mar 05, 2010 | HP Officejet J4680 InkJet Printer
HOW TO CONNECT PRINTER WITH PC?
first you have to connect with the power
then use the printer cable to connect the printer with your pc.
If you can mention the printer i will tell how to connect with the pc
Normally in new printers they use the USB cables to connect printers.
OR the parallel port to connect printers like dot matrix ( in this port there are only one port are in the behind the CPU it is a normally biggest connector )
Nov 07, 2008 | Epson LX-300 Matrix Printer
Cannot scan
hi,
first thing keep u r printer cd ready.Second uninstall your printer from add and remove programs and also disconect the printer from computer.Know re start your pc and install printer drivers with cd dont connect the printer untill it askes to connect. once setup asks u to connect connect the printer cable to your computer.Once the setup is finished then trie scanning from printer to pc. It will work.
Achanak3
Oct 02, 2008 | HP LaserJet 3050 All-In-One Printer
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
