Question about Fostex Mr16hd 16 Track Digital Recorder
I can't find the original manual for this recorder
    Sergeant:
  • 206 Answers
Http://www.fostexinternational.com/docs/tech_support/pdfs/mr16_owners_manual.pdf you'll have to have adobe reader installed in order to open the pdf but it too is free at www.adobe.com
Posted on Mar 18, 2011
Bounced trks 3&4 to 7&8 clicked on wav file button canceled says out of capacity
You have a memory problem. If you are using a flash card for memory or a CD drive or perhaps you have configured an external drive, you need to free up some space. Try deleting tracks or songs you don't need anymore.
Each song is independent on a CompactFlash
without affecting other songs. You can give a desired song name for managing recorded songs
(see pages 23 and 91).
Recorded track data is stored in a song as mono WAV files.
The MR-8mkII can convert the two WAV files recorded on tracks 7 and 8 (L and R) to a stereo
WAV file (see page 115).
You can export the converted stereo WAV file to your USB-connected personal computer, and
use the file by a music software application or make an original audio CD on the computer using
a CD burn software application. You can also burn an audio CD by using an external CD-R/RW
drive connected via the [USB HOST] port of the MR-8mkII (see page 115 and 123)
Fostex MR 8MKII Owner Manual Page 73 Fostex MR 8MKII Owner Manual Exporting Data To Personal Computer...
Are you using the auto delete feature? Get rid of data you don't need here: http://www.manualslib.com/manual/53326/Fostex-Mr-8mkii.html?page=135#manual
May 25, 2015 | Fostex Mr8 Mkii Mxl 990991 Recording...
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
No power when switch on with 9 v DC transformer
Is the transformer you are using the original? or are you using one that you picked up. If it is not the original, you have to make sure that the voltage and ground on the plug matches what the unit needs. Some adapters reverse the + and - on the tip and sleeve on the plug.
Mar 13, 2015 | Roland BOSS BR 600 8 track portable...
I have a zoom h4n. I can't get anything but low record levels. I have tried manual and automatic level control. The manual says I should select auto rec and then select start lvl, but when I select auto...
I use an earlier model but try:
Press the "red" light on the correct channel you are using for input. that will bring up the dialog to set input level. the +/- level set is on the same side of the device as the menu wheel.
You need to be in 4CH mode for the external lights to be on
Dec 03, 2017 | Samson Technology Zoom H4N Handy Digital...
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
Obsolete instuction manual
  • http://static.fixya.com/Manuals/F/Fostex/Mr_8hd_CD_8_9560CD0193FD88FFF2BDF0CB4FC4A17E.pdf
or
  • http://www.fixya.com/support/p926153-fostex_mr_8hd_cd_8_track_recorder_with_c/manual-31688#
May 02, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Fostex Mr16hd 16 Track Digital Recorder Logo
48 people viewed this question
Top Fostex Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Fostex Music Expert? Answer questions, earn points and help others
