Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Hello! I have a wfk 2400 Bosch washing machine and when I put it on to wash it has flashed the error code 1 and is not working at all. Any ideas? Thanks
  • 223 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 880 Answers
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Posted on Dec 01, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Can I stack my bosch wfk 2401 on top of my bosch wtl 5400
I wouldn't. Not without a proper shelf for the washer.
Washing machines are heavy because there's a huge lump of concrete placed over the drum to dampen down any vibrations. A tumble dryer is hollow, has little structural strength.
Put the machine on top of the dryer, you're going to get a crushed dryer if not a crushed foot, leg or child. Please be very careful.
Nov 11, 2011 | Bosch WFK 2401
Bosch WFK 6030 manual
Please check this link, it will help you with the working operations and trouble shooting:
washing machine advice
Oct 29, 2011 | Bosch WFK 2401
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
What does flashing error code 2 on Bosch a WFK 2800 washing machine indicate
Problem from heating. Could be element or wires from it
Oct 21, 2010 | Bosch WFK 2401
My front loader washer does not agitate during
It is possibly the motor brushes. worst case scenario is the motor complete.
Jul 05, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have an 03 error displayed on a Bosch WFK 2801 washing machine. Error only shows when machine is used with high water level function selected, otherwise it works. Why please?
Nov 30, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
281 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
